Low lan connectivity or limited lan connectivity
  • 1,011 Answers
Hello Sir,
all computers on the same physical subnet need to have ip addresses in common
meaning the first three numbers in aaa.bbb.ccc.ddd are the same and are different only in the ddd portion.
In addition, the subnet mask must be alike or ensure that some ip addresses are not excluded
Typical subnet mask is or sometime
Usually, there's a gatway address; a target which is used to send packets out
of this machine and hopefully towards the other machine.
For all machines, use the Run->cmd and enteripconfig /allYou should have similar results on all machines, so look for major differences eg: gateway on one is or not shown while other have non-zeros,
or ip address on one start 169.254 another starts with 192.168
The 169.254.y.z addresses are pecuilar
ms article comments on auto-config:
example : IP-address assigned via Auto-IP-Configuration :
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Autoconfiguration IP Address.. . . :
Subnet Mask . . . . . . . . . . . . . .:
Default Gateway . . . . . . . . . . . . :
Good luck
Posted on Feb 29, 2008
Limited Connection Error
A limited connection on a Windows PC usually means that there is no connection to the internet on that segment. That is if you connect to the printer via a network switch or LAN. Newer printers can act as a DHCP server/router assigning IP addresses to LAN clients. It has no impact on your LAN if you do not want or need a connection to the internet. However if you want to access the internet from this PC I suggest you get a separate router and use that as the DHCP server on your LAN. Connect the PC and the printer to the router and disable the DHCP server on the printer. Also make sure that all devices (PCs and printer) are using the router as the default gateway. Once again if you don't need an internet connection the limited connection shouldn't worry you.
Nov 15, 2013 | Kyocera Mita Office Equipment & Supplies
Limited or no connection
Limited connectivity
If you get a 'Limited connectivity" on you LAN connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the router.
To fix this problem, right click on the LAN icon on the Task bar and then click Repair.
This will force the router to issue a IP address to the LAN card on the laptop.
Feb 11, 2013 | Computers & Internet
It has limited low conectivity my signal is strong but i still cant connect to the internet
Please update the WLAN ( Wireless LAN ) drivers .You may do so from the control panel>device Manager.To get the updated drivers,please contact where you need to use the serial no/ snid no of the system and select the correct operating system
Nov 02, 2010 | Computers & Internet
Lan cable is connected but i have limited access and no internet connection
You first check type of your internet. Is it through LAN or other way?. If it is LAN through your broadband router plz select obtain IP address automatically in LAN settings. It will solve your problem
Sep 18, 2010 | ASUS P5P800 SE Motherboard
CF19 LAN connection problem
Hello there, have you check your LAN IP?Make sure that your LAN IP is uniqe from other pc on your LAN otherwise your connection will be limited.
Mar 28, 2010 | Panasonic Toughbook 19 Laptop Convertible...
LInksys WRK54g-wireless connection works fine, but cannot get LAN
You might have faulty LAN ports on your router or your network cable is bad.
Jan 23, 2010 | Linksys Wireless-G Broadband Router
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Lan troubleshoot
If the LAN status says limited or no connectivity it only means one thing the PC is not getting a valid IP from the router , first thing to do here is that was working fine before is to restart the computer and if after that still not working restart your router and your modem to refresh everything...
Jul 10, 2009 | New Media LANSurfer 56K/100 (NMC07021)...
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
Mar 24, 2009 | Toshiba Satellite L355D-S7809 Notebook
Connection problem
it may be LAN card issue please check NIC.
Reset your switch.. and try..
May 07, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
332 people viewed this question
David Payne
David Payne
