Question about Philips 23PF5320 23 in. HD-Ready LCD Television
I have 26in polariod lcd im using as computer moniter
Wel i connected it w/ a vga cord and it works great and all but i cant seem 2 figure out how 2 make the sound audio from comp. 2 play through t.v. i have a hp slimline by the way
please help me
  • 476 Answers
There should be an audio input next to or near the VGA connector on the TV. Usually red & white RCA or 3.5mm socket.
Connect this input to the audio or speaker output on the PC.
Posted on Feb 29, 2008
My gateway computer power light blinks and moniter says no signal.turn it off held then power button on for 30 seconds.then turned it back on.same as before.
I don't think this has anything to do with the monitor since it is showing "no signal". this is an indication that the monitor is working.
Problem is from the connection between the computer and the monitor or from the computer itself.
Check the VGA cable and make sure it is firmly fixed into the computer and monitor.
Open the computer case, disconnect the keyboard, mouse, and every other thing apart from the VGA cord, then try again.
If there is still no signal, turn computer off again, remove it's power cord, then remove the system Ram, clean it and fix it back in. Then make sure the VGA card is well fixed into the mother board. After that, connect only he VGA cord and try again.
If non of the above seems to work, connect the computer to another monitor, and connect the monitor to another computer in other to confirm which is having a fault so that we can focus on it.
Keep me posted.
Good luck.
Jul 11, 2011 | Smart Modular SV3170A
I cant figure out what chords i need
Take the monitor to any computer-store.
They can inspect the connectors, and sell you the correct cords (not "chords").
Mar 03, 2010 | Star Logic 17" LCD Monitor
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Getting sound through mogen lcd tv
Yes, you need a 3.5mm male mini stereo to male mini-stereo cable. Plug into small hole in monitor to lime green port of computer352d_2.jpg
Jul 06, 2009 | Computers & Internet
What dvi cable do i need?
Any bog standard dvi cable should work. As should a dvi to vga converter. Dvi is by far the better interface, and I would highly recommend using it, without any converters. I don't believe you can up convert vga to dvi, but you can certainly downgrade a dvi signal to vga, but i can't see why you would want to...
Oct 17, 2008 | Computers & Internet
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
VGA
open it up and look for defective capacitors on the video input board and replace them. Should probably replace the 470uf caps on the power board while you are in there.
Jul 29, 2008 | Gateway FPD2185W 21 in. LCD Television
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
Using your television as a moniter for your computer
check www.repairworld ,dalbani.com parstore.com they might have what you are looking for
Jun 11, 2007 | Samsung DVD/VHS/MP3/SVHS Playback
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
