Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool fridge freezer
We have a Whirlpool American style side by side fridge freezer which we bought from the previous owner of our house last year. It was working fine but found last weekend that we could not open the freezer door. It is stuck solid. At first the ice would not come out of the dispenser either so I wondered if it had made too much ice and was somehow stopping it from opening. I switched it off overnight and this morning managed to get ice from the dispenser but still can not open the door. Any ideas?
  • 2 more comments
  • michelle440 Mar 03, 2008
    Thanks for the suggestions. It is not stuck more at the top or bottom. It is stuck fast all over. Have tried brute force but it won't budge! Will bear your suggestions in mind.
  • michelle440 Mar 04, 2008
    Following on from this, we have now managed to open the door. We had to partially remove the door and found that there was a huge block of ice which had fused together the door and the internal shelves of the freezer. Not sure how this happened. It seems to have started at the middle part of the freezer where the water dispenser is as there were huge icicles from this point downwards. This had spread all the way down to the bottom of the freezer where all the food was enclosed in a block of ice. I can ony guess that water has leaked from there somehow or the ice dispenser was full but the ice maker was still taking in water to make more ice. We are in the process of fully defrosting it and will then switch it back on and see what happens. Any suggestions?
  • jbiggy85 Jul 03, 2008
    im trying to remove an ice dispenser motor but i cant get to it inside the door, the model number is GS6NBEXRL00. I got the drive shaft out and took out two screws but that plastic cover wont let us get to the motor. I tried prying up underneath the plastic lip to see if i could find a plastic latch or something...but I just cant figure out how to remove that cover, if there is anybody that has any ideas please let me know
    thanks
  • 1bailey1 Sep 25, 2008
    Same problem - GS6SHEXNT00
Bottom freezer door stuck closed
Posted on Apr 12, 2009
    President:
  • Whirlpool Master
  • 2,651 Answers
Trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Posted on Mar 01, 2008
  • Ron Coons
    Ron Coons Mar 04, 2008
    sounds like your water inlet for your ice machine has gotten stuck open(filling with water). possible that the water fill tube has dislodged from the ice maker fill cup, and instead of filling ice maker its leaking into cavity
Fridge/freezer freezing up
common issue on uk samsung rsh1 american style appliances
easy cured - diy repair kits been on the market a few years now
watch this youtube video for some extra help
Jun 10, 2014 | Samsung RSH1DTMH American Style Silver 524...
No ICE or Chilled water
Colin,
The water line is fine (what about water inside that line). Please check the source of the water line, I am sure when the previous used it they might have shut the water valve somewhere. Check your basement for that small valve etc.
Feb 27, 2014 | Whirlpool Refrigerators
Where can i find the model number on my whirlpool fridge freezer, American style?
open fridge door and pull out second from bottom draw - the sticker is on the righthand side
Jan 03, 2011 | Whirlpool Refrigerators
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Plumbing in fridge/freezer
That is the water inlet for the ice maker. It is 1/4 inch diameter and will need to connect to a valve of that size with 1/4 inch plastic or copper tubing.
Please rate if this helps-
Mar 23, 2009 | Whirlpool Home
Flickering display panel on Whirlpool american style fridge/freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Jul 16, 2008 | Whirlpool Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
1,017 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
