Question about GPS
Should my garmin 260 work while it is plugged into the power source?
    Scholar:
  • 57 Answers
Yes. If you're in your car and you turn off the ignition and it wants to go to battery mode while it's plugged into a cigarette lighter, check one of your other lighter plugs. My car has a plug that is hot all the time and one that is only hot while the car is running.
Posted on Feb 29, 2008
Garmin Nuvi 260 Car GPS Receiver
When the charger is plugged into the unit, look at the main menu screen. If the charger is working correctly, the green battery icon in the upper right-hand corner eill go out. If the charger is plugged in and there is a light lit on the charger but you see the green battery icon in the upper right-hand corner of the screen on the main menu, then the unit is on battery power and the battery is not getting power from the charger. Common problem with these units are loose rear USB ports. More information can be found here:
http://www.sharc.net/gps_charger_repair.htm
Sep 06, 2013 | Garmin nuvi 260 Car GPS Receiver
Garmin gps doesn't work when charging with cigarette charger. Instead of the GPS to Navigate it rather shows like there's a data transfer.
The proper vehicle power cables for the Garmin nuvi 260 are part numbers 010-10723-06 or 010-11478-03.
The use of improper cables will cause the nuvi to go into mass storage.
You may also want to contact Garmin Support for assistance.
http://www.garmin.com/us/support/contact
Sep 23, 2011 | Garmin nuvi 260 Car GPS Receiver
Garmin nuvi 260 does not work when plugged in
I assume you mean when you are trying to plug in to your car?
Have you changed car plug lately?
You have to use a Garmin approved car adapter.
Jan 30, 2010 | Garmin nuvi 260W GPS Receiver
How do i charge garmin nuvi 260 it doesnt chare while plugged into car lighter which is the only power source it comes with
TRY CHECKING THE FUSE IN THE END ON THE GPS CHARGER, THE TOP WITH SPRING LOADED TIP UNSCREWS TO LOCATE IT, THAT IF YOUR CAR LIGHTER IS WORKING, TRY A USB /MINI USB FROM YOUR PC/LAPTOP TO SEE IF THE GPS UNIT IS ACCEPTING CHARGE
Dec 12, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
Brand New...Can't get it to stay on?
Make sure you have it connected to a power source properly. Push and release the power switch. (it is spring loaded) Don't push it to the lock position for now.
Jun 07, 2009 | Garmin nuvi 260W GPS Receiver
New Garmin 260 W won't do anything when plugged in.
The Garmin doesn't need to plug into anything to work normally.  Just turn it on!
Dec 26, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi stopped working and won't restart
Got a Garmin Nuvi 260. Same problem. I read the booklet. There's a reset button on the bottom. Disconnect from power. Push the reset button. Connect back to power. Now it works. The reset button is tiny and looks more like just text on the bottom sticker than it does a button. But push it anyway.
Aug 06, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
64 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
