Question about LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
No Power We used this machine for 3 months; it powered down in the middle of a cycle, and now will not turn on at all. We've checked the outlet and cord, and there was no problem there. What could the problem be?
  • doodlebuggy Feb 29, 2008
    Hi there, thanks for your response; the Model # is: WM3677HW, and SERIAL# 607KWKS00277. I look forward to hearing from you.
  • 290 Answers
You will need to remove the top of the machine and check some voltages with a volt/ohm meter.
Please post the exact model and serial numbers from the machine and I will try to walk you through the troubleshooting process.
Thanks, Mike
Posted on Feb 29, 2008
  • 1 more comment
  • Michael  Lindley
    Michael Lindley Mar 01, 2008
    Thanks for the numbers. The only information I have is from a 2002 training program. Your machine was built July of 2006 so I hope this information helps you.
    I understand your problem to be that nothing is lighting up on the control panel. This is what the manual says about this problem.
    Remove the top panel from the machine and follow the power cord to the main power control board. Make sure you have 120v where the cord plugs to the board. There is a red LED on the board, If it is not lit up, replace the main control board. If it is lit up the problem is probably the display board, but could also be the main control board. Replace one, if that doesn't fix it, replace the other one.
    There should be a tech sheet in the machine when you remove the top that may have more detailed diagnostics. One of the biggest problems we have with LG is the lack of support information to troubleshoot problems but they make up for it with the price of their parts. You can buy the main board and display board together for less than $150. You can go to sears.com, click on parts, enter your model number and see parts diagrams and lists for your machine. They are kind of high on their parts but they have the best parts database I have found online.
    Let me know what you find out or if I have misunderstood your problem. I will try to find a service manual and let you know if I find any more information.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Mar 05, 2008
    doodlebuggy
    I found another repairman that had a service manual for your machine. It gave the same instructions for diagnosing your problem as the info I posted earlier.
    Let me know what you find out.
    Thanks, Mike
  • Michael  Lindley
    I almost forgot, Your machine has a 2 year warranty on the electronic control board. This covers the part only, not the labor. The phone number to find an LG servicer is 1-877-714-7486, or go to www.lgservice.com
    Mike
  • 4,102 Answers
Hi the problem is more than likely an internal fuse on the circuit board to do repair yourself youll need to get schematics and a multimeter and test the fuses on the board but as you have only had it for 3 months it should be covered by at least a 12 month warranty
  • paul proctor Feb 29, 2008
    Also have you checked the fuse in the plug if this is fine then its going to be circuit problem
LG washer #WM2655HVA won't start again after a cycle, unless unplugged, hand-turn drum, makes a beep, static spark as plugged back in, then a new cycle begins. Why?
Have you checked the wall power outlet for proper ground and
polarity? Try using another outlet near by using a "heavy duty"
3 prong extension cord. If problem persist chances are the Main
PCB is bad.
Aug 15, 2014 | LG SteamWasher Series WM2655HVA Laundry :...
Yesterday, my Keurig was giving me trouble with the menu, but it still made my coffee. That was the first time my coffee machine has ever given me trouble over the nearly year and a half I've owned it....
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Jul 05, 2011 | Keurig Elite B40 Coffee Maker
I've had the Keurig B60 about 6 months. It has worked fine until yesterday, when the power went out and will not turn back on. I checked the breaker and switched outlets, to no avail. The power just...
heatman101
Jun 25, 2011 | Keurig B60 Coffee Maker
The child/safety lock won't release at the end of a wash cycle so I'm unable to take my clothes out of the machine. I've tried a different cycle, turning the machine off, and switching the...
Thank you for contacting fixya.com.
You did not mention the type and the brand of your washing machine. However given bellow are some options you can try.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
In Hoover washing machine try holding down the temperature and eco/rapid options together to turn off child lock. Some series use "TEMP and OPTION" at the same time.
Please get back to us if you have further query else please accept the suggestion
Jun 17, 2011 | Washing Machines
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
No power
it sound like the lower board has failed check that ther was no water leaks from the valves into the board also check that the resistance on the valves are the same if they are diffrent this can blow the board as well. hope this helps.
Jan 28, 2008 | Fisher and Paykel (IWL12)
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
100 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
