Question about Vacuums
I have a samsung SC7800 (smart wing system) vacuum cleaner. I think the impeller is jamed with sawdust. I have removed the part than holds the removable filter, but can't see how to remove the reat of the top case to access to impeller housing. Does anyone know how to do this or where I can view a repair manual for this model?
  • 75 Answers
Unfortunately these tend to break frequently.... You might be able to get a wiring diagram at www.wize.com Good Luck!!
Posted on Feb 29, 2008
Why does it emit a high-pitched squeal (while running)?
This is usually caused by a belt being too tight or the wrong size. It can also be caused by something wrapped around the brush (like loose thread from a rug or yarn, shoestring etc. Try inspecting the brush and belt.
Dec 07, 2015 | Hoover UH70120 WindTunnel TSeries Rewind...
How to remove bissell rewind smart clean vacuum motor
You should contact one of our Authorized Service Centers to have a qualified technician inspect your vacuum to ensure you don't void your warranty. Here's a quick link to locating one. http://www.bissell.com/service-centers/?cid=ccsocial.
Dec 27, 2012 | Bissell Rewind Smart Clean Vacuum Cleaner
Does not dispence water and cleaner consistently.
If you have stored your cleaner with cleaning solutions in it you have a broken impeller in your water pump. The cleaning solutions separate while in storage and build up in your pump. Once you start the cleaner is breaks the plastic impeller. Its an in-expensive part but, a real pain to change.
Feb 15, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Spilled oil in boot of the car how do you get it out
put down cat litter or sawdust and sweep it out. repeat this until no more will absorb. then if it is carpeted use foaming spot cleaner and follow the directions. If not carpeted, use Dawn and warm water to remove remaining residue. ( this will work okay on carpet as well, if you have nothing else to use.) farmerbear at FixYa.com
Sep 30, 2010 | Vacuums
It won't pick up the water
sounds partially clogged, remove bottom plate and the rear exhaust assembly, make sure all passages are clear for anything stuck to it, check around impeller for same, hope it's not just full
Jan 31, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Dyson DC25 is squealing. Can you please help
It could be 1 of 3 things:
1. The belt that drives the beater bar.
2. An impeller that has a broken wing or 2, throwing it off balance.
3. Or, the bearings in the motor are going out.
Hope this helps,
Jim
Please Rate this Solution: THANKS!
Dec 01, 2009 | Dyson DC25 All Floors Bagless Upright...
Electrolux "The Boss" 4110 Vacuum - Have to hold power button?
It sounds like the on off Switch is broken.
you need to replace it or tape/glue it down and use the plug as on of switch.
Jul 12, 2009 | Electrolux Boss Smart 12A Vacuum Vacuum
Vacuum has become very loud screaching sound
Yes, I would say the crack is causing the screaming sound.
Usually the fan (impeller) is held on with a left-hand nut. To remove it, you have to hold the motor somewhere (sometimes you can just hold the impeller), put a wrench on the shaft nut and turn it clockwise. The impeller should then just pull off (with possibly some wd-40 and a little muscle).
Apr 22, 2009 | Vacuums
Smart Mix Dial - Reassemble Cover
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gfshsg
Dec 02, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
I think I picked up a nail with my Hoover Legacy Two, Vacuum Cleaner. It made a terrible sound and i sh ut it off immediately. I can't locate our manuel. How do I get into the propeller area, to extract...
I removed the plastic tip of the suction adjustment lever, and then easily pried the plastic housing covering and protecting the motor. Once the motor was exposed one could see the 1.5 inch screw, quite easily. With a pair of vise grips the screw, with some difficulty, was extracted from the fan wing. I replaced the housing and found the vacuum cleaner worked as well as before. I applied goop to the lever tip, put it back where it belonged, and allowed it to dry overnight.
Aug 21, 2008 | Hoover Vacuums
Vacuums Logo
96 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
