Question about HP LaserJet 1320 Printer
Card Stock Jam
I have a card stock jam. The suggestions in the manual do not allow me to view the card stock. In other words I can not view the card stock after following the manual suggestions.
  • carenandmike Mar 02, 2008
    I also have a card stock jam. I don't have the manual. What should I do?
I just thought I had a card stock jam.
Posted on Mar 02, 2008
I cannot free the paper in the jam in my samsung laser printer ML-1640/ml-2240 model
place a piece of card stock in the fed tray. turn on the printer and manually assist the card stock between the rollers. you may need to turn the printer off and on several times before it comes out the exit and moving the jam out.GL
May 02, 2011 | Office Equipment & Supplies
Getting paper jam message but there is no paper jammed will not reset itself
Generally, when a paper jam message is displayed, there is in fact some sort of debris, dirt, or paper pieces blocking the paper jam sensor. My suggestion, take a thick piece of card stock and manually feed it through the paper path; this should hopefully clear any debris that is blocking the jam sensor in that area. Also, try spraying some canned air into the paper path, as if there is dust blocking the sensor, it will be more likely to be removed with air than card stock.
-David.
Nov 03, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
After setting the paper type to card stock to thin card stock or special because this all I can pick the thing jams all the time.
This happens to be one of my least favorite printers.
Here is my suggestion:
Open up the cover and remove all 4 of the imaging units (with the toner cartridge). Also, remove the Fuser. While removing them, look for any bits of paper that may have gotten missed while clearing the jam.
Replace all of the items above and see if the printer still has a paper jam. It shouldn't.
Since, I assume you are manual feeding the card stock (the lower drawer doesn't allow for card stock to be used), look at the manual feed opening. There should be a small metal piece about 3" wide and less than 1/4" thick. Make sure it's attached properly. Ours unseated itself and is continuing to cause manual feed issues. This can be fixed but requires a good portion of the printer to be opened up to reseat the little metal piece.
Hope this helps.
Oct 15, 2009 | Xerox Phaser 7300DN Laser Printer
Rec paper jam message.
Normal 0 I suggest you get a sheet of Card Stock (Heavypaper) and place it in the feed way. Then press the printbutton applying a slight amount of pressure on the Card Stock so itwill feed through the printer. The reason for this is in some cases Ihave been able to clear the paper track of debris that was deposited thereover time.
Worth a try, as I have fixed a number of printers thisway, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon Laser Class 8500 Printer
Carriage jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Jan 27, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark E234 Paper jam light wont go off
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 21, 2009 | Lexmark E234 Laser Printer
Paper jam constantly on
Jan 12, 2009 | HP Officejet 7130 All-In-One InkJet...
Lexmark X125 paper jam
Jan 07, 2009 | Lexmark X125 All-In-One InkJet Printer
T642 Paper Jam and Check paper stock jamming.
You need to change the paper type when using card stock, plain etc.
As for the paper jams; you need to check the exit sensor at the exit door, also if you have a duplex, 2-3 drawer you also need to check for jams.
Sep 08, 2008 | Lexmark T642 Laser Printer
Paper jam
Jun 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP LaserJet 1320 Printer Logo
260 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
