Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Wont post and buzzing noise
By xATOMx on Feb 29, 2008
i have a brand new MB and e8400 CPU and it wont post and makes an awfull buzzing noise near the CPU i have tried two different types of memory . i also tried my older e6700 with no luck .the little lcd just reads CPU INIT which is what it says when you turn the power supply on
Comments:
Mar 02, 2008
- this MB is a Maximus Formula and i have checked the cpu fan for noise by unpluging it also i had the 8 pin plug connected to the board not the 4 pin i have checked all the connections to the board they are all present also tried 2 different power supplies. sorry the "little LCD " is a small display that plugs into the MB and shows the posting routine .
Mar 03, 2008
- yes i have tested the MB out of the case still the same result also tried 2 types of memory and 3 different video cards and as i said earlier i have tried 2 CPU's an e8400 and an e6700 still no luck :(
i cannot check CPU and settings as it wont post .
Mar 03, 2008
- yes seems to me to be a hardware issue thanks for your help guys
Clarification Request
Posted by Hermit65 on Feb 29, 2008
Please explain 'little lcd"
Try these in the meantime:
The buszzing sound near the CPU could be the cooling fan not anchored properly or worn out.
Video cards make sounds when not properly connected.
Check everything twice with the MoBo manual as you install.
Take your time and be patient as you work.
Let us know what you have checked, okay.
Solution #1
posted on Mar 03, 2008
Somewhat Helpful)
Hermit65
Rank: Wiz  Computers & Networking  Expert
Rating: 84%, 72 votes
Hey Xatomx,
1. Let's check for shorting contact on that BoBo. By that I mean, make sure your MoBo soldering circuitry isn't touching casing metal in the back. The MoBo needs to sit 'insitu' on it's screws. Sometimes if it touches the case there is a short and warning sounds.
2. Are you using the same CPU on either MoBo? Try a different processor also.
3. Go over your Processor voltage and clocking settings.
4. Use different RAM and Viseo to see the difference.
5. Check your HDD, Power SW, Processor Fan, RESET carefully with the MoBo manual..
6. Try removing the MoBo from the case and keep it connected to the P/supply and Leds. Fire it outside the case and see what happens.
Sorry, but these are practical things any engineer would check for in troubleshooting: isolate the problem systematically.
Let us know what you find, ok.
Comments:
Mar 03, 2008
- Hey, did you try a different power supply?
I am beginning to feel your MoBo or processor either have a problem. I would start thinking warranty exchange route. No reason it shouldn't post after all these options. I hope you got it from good guys down the road from you. It would be best.
Sometimes if you buy from a local shop, it's good to ask them to test those beats at the counter till BIOS posts and the babay cries, then you can take it home ready to grow.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on Mar 02, 2008
Somewhat Helpful)
map9966
Rank: Guru  Computers & Networking  Expert
Rating: 89%, 1983 votes
Don't mean to butt in here but I'll bet the 4 pin_ATX 12v connector is not connected to the board. That 4 pin_ATX 12v connector give's the CPU it's power. Without is the system will not boot. Some boards will give off that weird sound you are hearing.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
915glgv audio header pins how to connect
Answer
motherboard manufacturers schematics for intel desktop board d865gvhz for l e d switches
Answer
sir you have asked me intel audio studio version ,It is 2.0 if u have serial number of this version... (More)
Answer
hi i bought a p5kpl-cm motherboard i connected everything like in the b ook but ialways have only a... (More)
Describe your Motherboards problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in Baltimore, MD
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
