Question about Kitchen Ranges
Kenmore Electric Stove - Gourmet Edition
Freestanding stove with 4 coil burners and a griddle on top. It has 2 side-by-side ovens. Regular size oven on the right and a small broiler oven on the left. Large oven doesn't get hot. Heating element checks ok. Bad thermostat? Need parts source because Sears has almost nothing for this. Need approximate manufacture date. Really don't want to replace it. Great Stove!
  • 5 more comments
  • kart47 Mar 04, 2008
    watugot, the model is # 628.9468890 and serial # 8M 77794. Thanks.
  • kart47 Mar 08, 2008
    watugot, where can I get a wiring diagram for this stove? Thanks,Don.
  • distac Jul 15, 2008
    SIMILAR ISSUES....WANT TO GET A NEW GRIDDLE & 1 LG/1SM ELEMENT REPLECED AS THEY ARE NOT WORKING WELL FOR MY G/EDITION BUT CANNOT FIND THEM. GREAT EQUIPMENT AND WANT TO KEEP USING IT. LOCAL REPAIRMAN SERVICED THE ELEMENT, THAT IS GOING GOOD BUT HE WAS NOT HELPFUL IN SOURCING ELEMENTS.
    -DP
  • tonyb511 Oct 13, 2008
    I have te Kenmore version 790.9462990 and I have an large oven that heats about 200 degrees hotter than the thermo is set for. I replaced the thermostat and it still gets 200 degrees hotter in the main oven.
    I really thought replacing the thermostat would do he trick but no..
  • lyndahalernc Dec 29, 2008
    I have te Kenmore model 790.9462990 also. I lost the owners manual and can't figure out how to get the self cleaning to work.
  • HawkHacienda Mar 15, 2009
    I too have lost the owner's manual to my Kenmore 790.9464990. It needs to be self-cleaned in the worst sort of way! Also the auto-start no longer works. The timer works but the Auto-start does not turn the over on. Problem is with the standard size oven.
  • Michael  Lindley
    Michael Lindley May 11, 2010
    Please post the exact model and serial numbers from the stove and I will see what I can find out.
    Thanks, Mike
Hello! I have this stove in black where something went bad inside last week (made like a crunching sound). It still runs but seems to only be getting 110 electricity. Clock and lights work and the large oven stays warm. Everything was working fine until this happened. Could be an inexpensive fix- I willing to sell it for repair or parts if you are interested. The griddle alone sells for $170.00 through Sears. Cynthia
Posted on Jan 01, 2009
  • 290 Answers
Thanks for the numbers.
The 628 in the model# tells us it was built by Frigidaire. The date code in the serial number is less clear because it is a different code than their current serial number designations that have been in use since the mid '80's. The style of the stove makes me think late '70's, I would guess '77 or '78 from the first 3 digits of the serial number.
The thermostat should be easy to check. If the broil function in the large oven works, the thermostat should be ok. It is a simple switch that should read closed across the contacts when you turn it to any temp setting when the oven is cool.
The power for the oven will also go through the selector switch which routes the power to different components depending on the setting.
The power also goes through switches in the clock that allow the timed bake and self clean functions to work.
If there is no wiring diagram in the stove, you will probably need one to diagnose the problem if the thermostat checks ok. I would suggest getting one while it is still available in case you need it in the future.
Once you have found out exactly which part you need, you should be able to use the Frigidaire part number from the parts list on the Sears site to track down a replacement part through a local appliance parts dealer. You may have to take the part to them to try to visually match up a replacement. Thermostats and selector switches are usually pretty generic in their operation between manufacturers, the problem lies in finding one that will mount to your control panel properly and that your knob will fit so that you can keep the same uniform look along your control panel.
Please post back with what you find out or if you have any questions.
Thanks/Mike
Posted on Mar 04, 2008
  • Michael  Lindley
    Michael Lindley Mar 09, 2008
    sears.com shows the wiring diagram to still be available, prt# 3201592, $5.23. It is listed but not illustrated. You should be able to order it from sears or any frigidaire parts dealer.
    Mike
I need to find a manual for a 1959 Kenmore gas stove
I have a 1959 Kenmore gas stove with the original owner's manual. My stove is a 36" with griddle in the middle, a rotisserie, and a small electric oven on the left side. Very unique. Please contact me for further information. Mary
Sep 17, 2013 | Kitchen Ranges
I have a kenmore 953 freestanding stove, my wife was making pizza and the oven made a strange sound, the display is no longer working, the oven stopped heating, and she attempted to turn on the burners,...
If you will type "SearsPartsDirect" into your search engine, you can then enter your model number and you will see all the parts of your stove.
What should have happened was, either an element failed, or the element wire connection inside the wall of the oven failed, or a wire has "toasted" in the electric box inside the back of the stove.
You will need to take the oven out (away from it wall, perhaps) & give it a good inspection with an electric meter to find out where the problem lies.
God bless your efforts.
Oct 02, 2017 | Kenmore 9535 Electric Range
My kenmore electric oven works on the 4 burners on top, but the oven part does not heat at all.
There is an upper and lower burner, since it's not heating at all it's either your gas control valve or your temperature control board.
Note: If you have Sears service come out to repair your stove beware, We had them fix our stove. They told us there would be a $65 charge for them to come out but if we had the repair done it would be included in the repair price. Instead after they had our stove torn all apart they told us we would have to pay both charges or they would just leave with our stove in piece and we would still owe them the $65.
Jun 11, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
I HAVE AN OLDER MODEL KENMORE LIMITED EDITION STOVE/OVEN. I DON'T HAVE THE MODEL NUMBER OR OWNERS MANUAL. ANYWAY, I HAVE A PROBLEM, I TRIED TO USE THE OVEN BUT AFTER I SET IT " F5" COMES UP AND IT BEEPS...
you can get the model number and serial number from the oven, just open the oven drawal and get the number and call the customer service from where you got this oven from.
Dec 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
2,415 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
