Question about Refrigerators
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could be/is frozen above this point. Still no ice 24 hours later. Hear intermittent buzzing that sounds like water valve opening up too fill icemaker, but no water in icemaker.
  • Anonymous Mar 13, 2014
    Ice maker has,t made enough ice over night
  • Anonymous Mar 20, 2014
    the icemaker make ice but I can not drink water
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Posted on Feb 29, 2008
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
My whirlpool ed20db ice maker isn't making ice. Inlet tube is frozen solid
Thanks for the model number. The water control valve=> W10245167 Water Inlet Valve will need replaced when this happens. Problem allows water to leak slowly into the ice maker and fill tube can become solid very quickly, or very messy ice formations coming down from ice maker, Thanks John Tripp Appliance 911
Jan 28, 2014 | Whirlpool Refrigerators
The icemaker calls for water but no water comes into it
Starting from the start, make sure the valve behind the fridge is open. then make sure when you disconnect the tube from the intake of the refrigerator, that water comes out. Then check the intake filter on the fridge for debris. Then defrost the freezer in case the intake line froze. If you still have no water going into the ice maker, the valve is probably bad. If you post the make/model and go through those steps I'll help you take the Icemaker apart...
Oct 11, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I ice maker keeps freezing in our side by side GE fridge.
This annoying problem can have a variety of causes. Check these four things first:
  1. Make sure the water supply is greater than 20 psi. If too low, thewater valve won’t seat properly and it’ll “weep.” Common causes of lowpressure are gunked-up saddle tap valves, kinked water supply line, andusing a reverse osmosis filter to supply water to the icemaker.
  2. Check between the valve diaphram and valve seat for sediment. If found, do not attempt to repair, buy a new valve.
  3. Check to see if the black, flexible portion of the fill tube iswrinkled, twisted, or kinked which can cause ice dams that block thefill tube.
  4. Find out if the water has been shut off while the icemaker has kepton cycling. This, too, can cause the fill tube to freeze up.
If all the above checks out and you’re still getting fill tube freeze-ups,then best get a service guy to take a look. It could be a complicated repair.
Jun 24, 2009 | Whirlpool ED2FHEXN Side by Side...
I have a whirlpool gold refrigderator model# GS6NBEXRL00 and the ice maker is not producing any water. I replaced the whole ice maker and nothing happened. After unpluging and plugging the fridge back in...
you p robably have a frozen fill tube for the icemaker. coming inot the rear is a tube for dispensing water into the icemaker. check this for ice if it is frozen you can thaw it out by using a blow dryer to melt theice out. on some models this tube comes thru the back wall of the freezer for cross the freezer icemakers there is a black tube that comes out of the ceiling. if you have any questions please post here and I'll get back to ya thanks Peyton
Mar 06, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirpool fridge won't make ice
a loss of water supply to the refrig could cause this problem. check the fill tube that supplies water to the icemaker (this is the tube that omes into the rear of the icemaker) i think you will find it is frozen up. you can clear this out wiht a hair dryer. I just looked at a diagram for the model number you provided and the fill tube is the black tube that comes into the fill cup on the far right hand side of the icemaker. you will have to raise the icemaker door to see it. but heating this and clearing the ice will fix it thanks peyton
Mar 02, 2009 | Whirlpool GS2SHAXM Side by Side...
Ice maker
Check supply tube to see if frozen or blocked using Q-tip or feel to see if frozen. if Frozen, hold up clear glass with heated water placing tube in hot water. Hold till ice in tube melts. Clear glass will allow you see ice slip out.
Jan 19, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Ice-maker has no water in it
lift the service door in front of the icemaker so you can see the black tube to the right.squeeze it.is ot solid or soft.if solid,there is a kit that is just a heated fill tube.if its soft,look at the ice maker.where are the plastic fingers pointed?if you turned the icemaker sideways and looked at it,the fingers should be at about 1:30(imagine the hands of a clock.)if they are sticking somewhere else then you might have a bad module.(most often the case).when you open the door and see the light blinking,reach over to the left and just push in on the white flap of the receiver.as long as nothings blocking it,the light should go solid.
Jan 13, 2008 | Refrigerators
Refrigerators Logo
438 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
