HD reformat i want to reformat my HD but my disk drive won't recognized my Win XP disk (bootable). is there any way to reformat my HD?
Get Hiren's Boot CD. It has many utilities which includes data recovery, low level format and hard disk partitioning.
Posted on Feb 29, 2008
I am having a toshiba portage m205 with win xp . Windows got crashed when I tried to load windows with recovery cd It doesnt recognize its recovery disk Pls help .
you can do one thing
with that your data will be saved.
try a bootable cd of win XP & install os again without formating C: Drive, just overwrite the os instalation in same drive.
maybe after that your problem will be solved
Dec 30, 2010 | Toshiba Portege M205-S810 Tablet PC
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Acer Aspire One XP startup error
if the laptop has a floppy drive get a bootable win 98 disk. insert disk first then turn on comp. run w/o cr rom support. at command prompt type "fdisk MBR" hit enter remove disk and reboot. if still bad insert win XP disk and do the second repair not the first one let it run its course. if not well you will have to reimage the comp
Jun 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
DVD drive is not reading the Boot up disk
how many types of  bootable disks u hav tried,,,if d writer isdetecting d other ones den ur cd is faulty,hav u selected cd drive as 1st boot device or not
Mar 29, 2009 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
Trying to install a new sata harddrive but win xp does not recogn
check bios and set the parameters for the new hard drive. These parameter should be found on the hard drive itself
Dec 10, 2008 | Dell Computers & Internet
Hard disk
if you are installing a dos based system thn dos formatting is very good
if you are going to use xp then make boot option in setup as bootable from cd rom
put a win xp setup cd in the cdrom drive
it will boot up saying press any key to continue , and follow the scren instructions
the whole process is that simple a hd can be formatted till bad sectors are not shown up upto 8 %. more thna 8& bad sectors cannot load windows, however dos can still be loaded and so also win me so it doesnot affect the hd
what affects is the jerks and voltage supply variations on the har d disk and some bad virus infections and the temperature the hd has ... always leep hd at a tem p lower than 37 degres c
use a fan to achieve this a 12 volt small fan mounted on the hd .
Jul 29, 2008 | Computers & Internet
Reformat/Reinstall Refresh on hdd
You should provide either CD/DVD rom to boot your sytem in bootable disc.
And you should provide windows XP/2000 bootable disk.
You will need:
CD/DVd Rom
Bootable windowsxp/2000 to reinstall your system.
Note; reformatting or reinstalling your system all files will be remove. you should back up important files before doing.
Jan 14, 2008 | Computers & Internet
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
#1508 Bad directory buffer signature
Hi, if this is a fairly new installed XP you're probably better off: repartitioning, reformat and reinstall WinXP but this will delete all contents of the hard drive. If however there are a good number of critical/important files you would want to save/copy, there are two (2) ways of going about saving/copying those files but both involve access to a working computer. (1) remove your Travelstar 5K100 from the laptop and using a 44 to 40 pin adaptor, connect it to the working pc which should recognize it as another hd and therefore you can copy your files to that pc. There are many sites that explains how to do this. You can try Google search or (2) another method is to boot and run your OS from your cd. While this does not involve physically removing your laptop's hard disk, it might be a bit challenging preparing the bootable CD with an OS. The procedure is better explained at This will run your laptop although a bit slow however, you can access the hd and save it to a thumbdrive or if you have a lan to another computer. Please let me know if this works ok with you. Good luck and regards.
Mar 29, 2007 | Hitachi Travelstar 5K100 40 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
