Question about Sansui VRDVD5000 DVD Recorder/VCR
SAN0218250GB DVD + RW RECORDER - AUTOMATICALLY TURNS OFF
My system automatically turns itself off 30 seconds after being turned on. I can't watch TV, watch/record to HDD or DVD.
  • 1 more comment
  • jcw35 Feb 29, 2008
    Tried that last night - but no joy.
  • jcw35 Mar 01, 2008
    Tried the solution of leaving it turned off all night but didn't work.
    There could be a DVD inside the machine, but the DVD doesn't seem to spin when the machine is on.
    The timer stills seems to work and the machine tries to turn itself on to record as set, but is unable to to stay turned on and so turns off again - and repeats this process for at least 30 minutes.
    Unfortunately, the machine will not stay on long enough to change the source nor can I use the remote.
  • 86 Answers
That problem can also occur if there is a malfunction in the VHS side. If there isn't a tape in it, put one in then eject it. Also, if you think there is a DVD in, there may be a tiny hole next to the DVD drawer that you can take a straightened out paper clip and push it in until the drawer opens.
Posted on Mar 01, 2008
    Sergeant:
    Champion:
  • 281 Answers
Go to the settings of the DVD and you can change it from there. Thats a normal thing don't worry. Hope this helped you.
  • 790 Answers
HELLO!!
TRY LEAVING IT PLUGGED OFF OVERNIGHT!!!
Posted on Feb 29, 2008
How do I stop my Panasonic DMR-EH75V DVD Recorder from automatically turnig itself off after 75 seconds?
It could be overheating.. Is it fairly consistent at 75 seconds? To test put the unit in the fridge for 30 minutes then quickly connect it up and test. If it is longer then 75 seconds then something is getting to hot. I've put hard drives (especially laptop ones) in the freezer if I need to copy off data but it clicks/stops working at room temp.
Aug 10, 2014 | Panasonic Diga DMR-EH75V DVD...
DVD/VHS Panasonic DMR ES30V.I have a "digibox which, via the Autotune facility, has input "Free to Air" stations. However,I can only record/replay digital channels 1 - 5.others e.g BBC4...
Greetings,
channels 1-5 gets signal from the digital receiver.
and the other channels are from the autotune facility connected to the TV ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Panasonic Televison & Video
MXT DVD+RW RECORDER9 250 G Hard Drive
I would like to buy your dvd recorder, cause my one is broken and I need spare parts....
Please contact me! maaure@web.de
Greetings
Sep 16, 2013 | Televison & Video
My dvd player wont work it will just say hello when i turn it on but then it will turn off by itself
I have the same problem. I installed this unit and used it for a total of one day before it complely failed. When you tun it on, the display says hello, nothing is shown on the TV, and it turns itself off within 30 seconds. Solution, I am returning this JVC unit and never purchasing another JVC product again. Complete failure after one days use, pitiful!
Oct 10, 2009 | JVC DR-MV150B DVD Recorder/VCR
Can't get the tv back on the channels properly after watching a m
Change the input, look for the button on the remote or on the TV itself. Just changing the channel on the TV after powering down the VCR should also work.
Sep 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't record DVD+RW and DVD+ Disks...PLUS
Firstly, you need to finalize the -R disk recorded by and in your unit before it will play back anywhere else.
Secondly, the DMR-ES10 does not support +RW, only -RW.
Finally, I have never heard of a +D. Do you mean +R? It is likely that you have a corrupt disk; change it.
Mar 11, 2009 | Panasonic DMR-ES10 DVD Recorder
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Record a tv show while watching another show
You need to get either:
  1. DVD-RW [Rewritable]
  2. DVD+RW [Rewriteable]
Brands are Maxwell, Verbatim, Sony JVC, Staples etc
Hope this helps
Mike
Jan 05, 2009 | JVC DR-MV100B DVD Recorder/VCR
Dvd/vcr recorder stops recording
I found this web page. I think something similar is happeneing to me. It is on analog channels when it hits some commercials.
http://hdtv.forsandiego.com/messages/3/6915.html
Nov 02, 2008 | LG DR787T DVD Recorder
Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
May 08, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui VRDVD5000 DVD Recorder/VCR Logo
50 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
