Question about Yamaha RX-V730 Receiver
Yamaha RXV-730 6.1 Channel A/V Receiver
I have a Yamaha RX-V730 receiver and since the day it was purchased it was working fine, but when the volume was raised, the receiver would shut down. Once turned on a CHECK SPEAKERS message was displayed. I replaced all the stock speaker wires with Monster Audio Cable, and the cable changed seemed to have fixed hte error. However, in one incidence the volume was raised and the receiver was shut down and could not power up thereafter. When the power button is pressed a double clicking noise is heard and the receiver will not turn on. I checked the impedence level and it was set at 8 ohms, which is the power output of the speakers. When the impedence level is moved half way from the center to either the left or right side the receiver powers up but then shuts off within 3 seconds. I checked the fuse and the fuse looks good. However, when the power button is pressed the clicking noise can be traced to a relay in the Power Circuit Board. My guess is that it can be the relay or the fuse. Can you please help me find the problem and find a possible solution and avoid a high cost repair? Thank You For Taking Time Read My Post I was given this receiver by a customer of mine. I seem to have the same problem. The fuse appears to be fine I just wasnt able to check for continuity. At the4 moment I have no speakers hooked up to the system, in fact I dont have any thing hooked up at all. I checked the thepower on and all I get is a quick click sound. I watched the fuse and noticed a quick spark and observed the fuse jump slightly in the clips. I'm not certain but the click does appear to come from the relay just behind the fuse on the power board. I even tried placeing foil across the fuse clips to see if the power on results were any diffrent but no luck. Please if any one has a thought let me know.
  • 749 Answers
The clicking may have been coming from the relay itself, but it doesn't simply mean that the relay is faulty. clicking may also be caused by transformers, indicating that some electronic components have developed SHORT CIRCUIT. try measuring resistance of transistors and diodes near the power unit (unplug/turn the unit OFF of course) check also for the impedance of the output power transformers.
check the amplifier IC for short also.
Posted on Feb 29, 2008
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
Pushing 4 ohm speaker systems
Officially this receiver supports only 6 and 8 ohm speakers. But for surround speakers it should not do any harm, because they are not played at full volume. But be sure to set yamaha for 6 ohm speakers.
Using only 4 ohm speakers makes the amplifier work more hard and produce more heat, that's why you can't use it at high volume.
Nov 30, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha RX-V730 OSD problem
I assume you have a component connected source coming into the Yamaha to give it sync and you are component connected out to the monitor. If you have no input you won't have osd on component only without a signal to sync lock.
It is always possible that the 730 doesn't actually have component overlay for osd, just its a 2in 1 out switched affair. Hence the manual says you also need the composite/ Svid as well...They certainly don't use both at the same time. Newer units have full up + down video conversion but at this age it won't have.
Oct 31, 2009 | Yamaha RX-V730 Receiver
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
No output on left main speaker on Yamaha RX-V730
To the shop.Do a web search and check around carefully for someone with a good reputation.
I have a shop but I'm in Vermont.
Feb 23, 2008 | Yamaha RX-V730 Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Yamaha RX-V730 Receiver Logo
292 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
