Question about CHE-EZ Snap Digital Camera
Software will not load ,it says executable corrupt
Do not use it
Posted on Mar 02, 2008
WINWORD.EXE does not allow me to use word. Please help
executable file is corrupt or your software did not installed properly.uninstall the existing software and then install it again
May 28, 2011 | Dell Computers & Internet
Kernel missing or corrupt
First, try doing Alt-F10 at bootup. It's supposed to load erecovery management. This is where the recovery software is located. If you can execute it, you will be able to restore windows and still create another recovery set.
Now, if you have tried to boot into Safe Mode with Command prompt and this doesn't work, then you will have to contact Acer and order the discs. It'll cost about 50 dollars to order a recovery set from Acer.
Sep 30, 2009 | Acer Aspire 5610-4648 Notebook
I have the t42p thinkpad, i have been trying to get the ethernet software to load, no matter what i do it will not load i looked at the download files, they are dll's and there is no execute command so the...
after several attempts to make the device manager load this program as it is a dll program and not executable i had to erase the os and
reformat and start over. then it finally accepted the software.
Jul 28, 2009 | Computers & Internet
Error Message 'F:\ setup.exe is not a valid win32 application'
This issue can be caused by any of the below possibilities.
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Mar 18, 2009 | Computers & Internet
Uninstallation problem
Try this freeware, it will uninstall corrupted software.
Link:
http://www.revouninstaller.com/
Let me know if this helps.
Mar 15, 2009 | Computers & Internet
P62 error code
The IBM 6400 printer uses internal programming software that is specific to the printer based on installed interfaces and graphics options. This software resides in flash memory and when the printer is first powered on the software is executed. During this process it initializes the various processors on the controller board, initializes the optional interface cards, and then loads the necessary operating settings into dram. If the programming software becomes corrupt it will fail during startup, giving you the DC Program not valid error or a number of other error messages. The solution to this is a reflash of the printer. Unfortunately, the flash software is proprietary to IBM and they will not distribute it to anybody. The only way to get the printer reflashed is by calling IBM and having one of their engineers reflash the printer.
Jan 28, 2009 | IBM 6400 Matrix Printer
Lexmark X2470 printer wont print/connect time executable stopped
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Lexmark X2470 All-In-One InkJet Printer
Xerox Phaser 7300
You need to go to theExecute a NVRAM Reset in Diagnostic Mode sceren and find service diagnostics and Execute a NVRAM Reset. You most likely have some software corruption that needs to be cleared.
Dec 16, 2007 | Xerox Phaser 7300DN Laser Printer
Databecker 150 essentials
Check if it is a trial version if so avoid it
or
try to install it in another computer if you find the same problem CD may be corrupted
Dec 15, 2007 | Databecker 150 Essential Programs...
CHE-EZ Snap Digital Camera Logo
Top CHE-EZ Cameras Experts
Are you a CHE-EZ Camera Expert? Answer questions, earn points and help others
