My Insignia NP3 has a problem with the LCD screen all I can see is a big black spot when I tried to viewed the music videos I uploaded to it. At the dame time the screen is blurry. I don't know what's wrong with it.
Uyfy
Posted on Feb 29, 2008
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
The ASP Ratio feature on my Insignia ISEDPLTV42 doesn't allow a full screen view - only 2 large black areas on both the right & left sides. I have a Digital Video Recorder (DVR) hooked up to
the ratio you speak of is the 4x3 and the set may have locked on it--If you have not tried to: unplug the set from power for a while and plug back in to see if set will reset itself.
I presume you went into customer menu and checked to see if you have the option to change from 4x3 to full or 16x9.
Mar 27, 2012 | Insignia 42" LCD Flat-Panel HDTV
I have a big black spot in my sceen
If you are able to take good photo's through the view finder, then it indicates the LCD screen is damaged and will need to be replaced.
Mar 06, 2011 | Olympus FE-180 Digital Camera
No image on LCD screen
It sounds like you're receiving partial information on the LCD screen and that the image sensor isn't sending information to the screen.
If you know the sensor is working by recording some video on an SD card and being able to view the recorded video on your PC, then there is a disconnect between the LCD and the image sensor.
If you are not recording video to your SD card and only get black images or no files, the image sensor is damaged.
If you are recording video, but no image appears on your LCD for internal viewing/playback, you can try a firmware update if one is available from www.insigniaproducts.com, but this is a discontinued item so there's not much available for support.
Hope this helps!
Apr 25, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Black spots on LCD screen
you need to make sur about something:
the black spot, is it a dead pixels?
if it's not, canon will fix it for you free of charge as it could be a CCD problem.
Jun 26, 2009 | Canon PowerShot SD880 IS Digital Camera
Mp3 turns on but screen is black
This happens a lot with these units (not just insignia). The backlighting goes bad. The lcd probably works, but, because no light is going through, it just looks black. This happens a lot especially if they get wet (moist). Wrap them in plastic before going on a run. The good news is, these are inexpensive to replace on ebay.
Apr 12, 2009 | Insignia Pilot MP3 Player
Salvage TVs
A manufacturer wont sell you LCD screens that big unless you are factory trained. There is nothing you can do with a bad LCD. Now you are in a bad spot because you can no longer dispose of electronic parts. They must be recycled. The recycling centers charge for those.
Nov 05, 2017 | Insignia IS-LCDTV32 32 in. Television
Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
Aug 15, 2008 | RCA LCDX2722W 27 in. Television
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Growing Black Spots on Insignia LCD Flat Screen
Black dots/spots on an LCD panel display indicates either a dead pixel or a stuck pixel. Alternately, if you press lightly on the black spots and they go bigger/darker, then in some instances, it could be that the frame holding the display has been slightly warped when too strong a pressure was applied when it was being cleaned. Should this be the case then corrective measure would be to disassemble and flatten whatever area was dented. Some have reported success with the use of a suction cup. Perhaps this, this or this might be interest you.
If the unit is still under warranty, please try discussing your concern with your dealer. Though a few small spots are an acceptable norm. Alternately and if the warranty has lapsed, there are companies online that offer LCD replacement kits or will replace/fix your LCD and it would cost you less than the cost of a new screen or TV.
Other than the above, am afraid that your options are rather limited.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Insignia IS 20" TV040919 TV
50 people viewed this question
 Grubhead
Grubhead
