Hello - i have a casiofx250 calculator and i urgently need to convert from rectanular to polar - how do i do this ? raj
  • 113 Answers
This is an example, plug in your problem.
Convert 12 - 42j to polar form (r ∠ q).
For CASIO calculator...
Keystrokes Display 12 12 hello - i have a - rp.gif 12 42 42 plum.gif -42 eq.gif 43.68065934 (= r) hello - i have a - xy.gifrc="http://i.fixya.net/uploads/images/xy.gif" alt="xy.gif" class="h_mi" /> -74.0546041 (= θ) Therefore,
Complex number in rectangular form: 12 - 42j Same complex number in polar form: 43.7 ∠ -74°
Posted on Mar 01, 2008
Convert a polar equation to a rectangular equation?
To convert a complex number (not an equation) from rectangular coordinates to polar coordinates you do as follows
2+3[OPTN][ F3 (CLPX)][F1(i)][F6 >][F3> r ,theta][EXE]
Nov 08, 2014 | Casio CFX-9850G Plus Calculator
Polar rectangular
There is nothing to convert, because if T is a real number so is 40sin(4000T).
40sin(4000T)=40abs(sin(4000T))*sign(sin(4000T))
where abs() is the absolute value of it argument, and sign(sin(4000T)) is positive or negative.
So in (radius, angle) polar coordinates
r= 40 abs(sin(4000T)),
theta =(0, or PI), depending on sign(sin(4000T))
If you are trying to graph parametric functions, this calculator does not do graphs, and you need another function of T
Dec 26, 2013 | Casio FX991ES Scientific Calculator
Convert from polar to rectangular & vise versa using calculator with RCL&POL GIVE EXAMPLE JUST PROCEDURE THANKS 9
Examples #036 and #037 in the Appendix illustrate how to convert between polar and rectangular coordinates. If you need the appendix and/or the manual, you can download them from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
May 22, 2011 | Casio FX-115ES Scientific Calculator
How do I convert between the rectangular and polar form of a number with imaginary values? i.e. I want to take the number a+bi and convert it to polar D<(angle) and vice versa.
Use the >Rec and >Pol commands. They're in the Complex number menu, accessible through 2nd [CPLX] MORE.
[CPLX] is the shifted function of the 9 key.
Dec 10, 2010 | Texas Instruments TI-86 Calculator
Converting between Forms When working with phasors it is often necessary to convert between rectangular and polar form. To convert from rectangular form to polar form: M = sqrt{A^2 + B^2} f =...
You can switch the display mode for complex numbers by pressing SHIFT MODE down 3 and picking one. This will display the current result in the selected mode.
You can also override the current display mode and specify the format. Add these keystrokes at the end of a calculation: SHIFT 2 then 3 for polar or 4 for rectangular.
Nov 24, 2010 | Casio FX-115ES Scientific Calculator
How can i enter a polar form number with angle to convert into a rect form
how can i enter a polar form number with angle to convert into a complex numbe(a+bi)
Apr 28, 2010 | Casio Algebra FX 2.0 Calculator
Can you show how to convert pola to rectangular o
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Canverying polar to rectangular
Here are exemples from the manual.
May 03, 2009 | Casio FX-300MS Calculator
Polar/rectangular
For a TI-86
Converting rectangular to polar
Press "2ND" and then "MORE" for the MODE screen
Highlight PolarC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5+j6
Enter "(5,6)" in the calculator and press "ENTER"
Should get (7.81024967591*angle*50.1944289077)
Converting polar to rectangular
Highlight RectC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5*angle*35
Enter "(5*angle*35)
Should get (4.09576022145,2.86788218176)
Note
*angle* is the symbol when you press "2ND" then ","
Note 2
To round the an decimal places press "2ND" then "MORE" for the MODE screen and on the line that says float, choose a number on that line for the number of decimal places you would like to have.
More can be found at
http://docs.google.com/gview?a=v&q=cache:nAC57BtC6IIJ:myweb.wit.edu/khabaria/ELEC195_files/ti86cplx.pdf+ti-86+convert+to+polar&hl=en&gl=us
Dec 02, 2008 | Texas Instruments TI-86 Calculator
Computers & Internet Logo
159 people viewed this question
Alun Cox
David Payne
David Payne
