That code is a fixing error code, try reset it and with any luck it will work.
The problem discription is very long to be shared here, basically what you have to do is reset the copier
E000
The error history indicates any of the following error codes 4 times: E001,
E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear
the error.; then, turn back on the power.
It might be a good idea to get a service manual to get a good insite, here is the link for it;
http://www.techmanualarchives.com/canon-ir1630_1670-service-amp-parts--manual-25159.html
SOURCE: System Error E000
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used untill the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser overtemp means the fixing assy has exceeded the manufacures maximun temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no responce means the fixing assy didnt even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arow buttons to scroll to #4 printer reset press set.press the approprite arrow key under the YES to clear the error. unplg the copier and reboot. At this time normal function should return if not and it resets a E00 the nyou can assume either the fixing asy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to reserch the problem to avoid spending money on excess parts
SOURCE: System error E000
That's was a miraculous!!!!! My canon Image Class D860 is brand new now after following the steps.
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
This just worked for me on a D860
Thanks
Evenel
Press the "additional Function" key
Press the # key
Press F3 key until "Printer" shows up.
Press "OK" key
Press F3 key until "Printer Reset shows up
Press "OK" key
Press the * (star) key
Turn printer OFF then back ON
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
