Question about Brother DCP 115C All-In-One InkJet Printer
Dcp 115 c
Machine error A7-PARAMETER INIT...what should i do...?
  • qafi Mar 06, 2008
    what is CIS..?
Black color won't work in rpinting, but the rest are okay, so what i did evertime i print documents i highlight the text to other color than black instead, so my question is what the remidy for this., thank you
Posted on Aug 19, 2008
  • 832 Answers
Did you change the CIS scanner (because of broken glass or stained with ink?)
The eeprom parameter is not machting with the scanner type!
You cant fix this by yourself. Needs special software only provided by brother.
Another solution is to use another scanner top with identical parameters.
Posted on Mar 01, 2008
  • Mix-it-up
    Mix-it-up Mar 06, 2008
    Did you change the scanner (which works as a so called CIS vs. CCD = but dont mind the technics) and use a diffrent one from another dcp?
    The error occurs only when a wrong scanner tube (there are diffrent types manufracted by brother within a series) is installed/connected to the main board.
Unable to init 4f
Problem with Brother DCP-J125
Unable to init 4f
Aug 06, 2013 | Brother DCP-J125
Dcp unable init
I have got an error "Unable to Print 48"
May 15, 2013 | Brother DCP-J125
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Will not clean servies
Brother MFC-5440CN Unable to Clean error and may work for some others.
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 04, 2010 | Brother DCP 115C All-In-One InkJet Printer
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
The error messageunable to init
you have to replace the print head.
But to be honest: its cheaper to buy a new dcp 135c or 130c with warranty and new carts incl.....
Mar 12, 2008 | Brother DCP 115C All-In-One InkJet Printer
Printer not printing
you need to get error code then go from there.
110's,115, 215,210,415,640 etc etc are all the same engine there abouts..
prob error 41, forget it!
http://www.fixya.com/support/t246971-unable_print
Nov 11, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother dcp 115c + machine error A7
Value of machine is not worth me typing to explain how to set coorect value when it probally needs main pcb or scanner unit.
but if you want to dig around heres a pointer
Correct the ROM data.
Set up the CIS by
Function code 59
Nov 09, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
162 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
