Question about LG CU500 Cellular Phone
I can't get my LG TU550 to dial out from my MSI Laptop
Hi, I have a MSI Megga Note-book 740 Duo-Core on an 800 FSB with 2 Gig RAM. I want to dial out through my LG TU550.
My laptop has fount the TU's modem,, but it just won't ring out
I don't want to connect to some sevret server some where,,,I either what to dial in to my own server, or dial in to another cell phone and transfer the data to that computer
MAX2333
  • 3 more comments
  • max2333 Feb 29, 2008
    Telstra Australia,
    there are 2 programs I want to use
    Internet explorer,
    and Northa, ( for road side message boards)
    the problem seems to be in the phone, or the phone isn't being triggered
    Sorry, I just re-read your question.
    The phone computer connection uses the LG TU550 USB Modem software that came with the phone. I have trided all the settings in phone Manual, and some, keeping carefull track of what I changed and then reversing the changes when it didn't work. My gut feeling is it is still somthing I have not turned on in the phone, but , hey, if my gut was right, I wouldn't asking you?
    Max
    Hi, it imediatly says faild to connect, whether it's to my ISP, dial in ot to the other mobile phones. I should also say, the phone works properly as a mobile when not pluged in to my laptop. And I can do a,LGE Mobile USB ModemProperties, Diagnostis, Query Modem, Successfully.
    Results below
    ATQ0V1E0 - OK
    AT+GMM - 226
    AT+FCLASS=? - +FCLASS: (0-1)
    AT#CLS=? - COMMAND NOT SUPPORTED
    AT+GCI? - COMMAND NOT SUPPORTED
    AT+GCI=? - COMMAND NOT SUPPORTED
    ATI1 - Manufacturer: LG ELECTRONICS
    Model: 226
    Revision: TU550-MSM6275-V10f-SEP-07-2007-TEL-AU 1 [Aug 28 2006 16:15:00]
    IMEI: 355855012163020
    +GCAP: +CGSM,+DS,+ES
    ATI2 - Manufacturer: LG ELECTRONICS
    Model: 226
    ATI3 - Manufacturer: LG ELECTRONICS
    Model: 226
    ATI4 - Manufacturer: LG ELECTRONICS
    Model: 226
    ATI5 - Manufacturer: LG ELECTRONICS
    Model: 226
    ATI6 - Manufacturer: LG ELECTRONICS
    Model: 226
    ATI7 - Manufacturer: LG ELECTRONICS
    Model: 226
    Hope that helps?
    from home by fixec line, & ethernet to DSL to the same ISP, the ISP Account is fine,,,via the inbuilt Motorola SM56 Data Fax modem.
    where would I find a lits of, extra string initionlization comands. it's like there is a command missing
    Max
    Hi otacon
    yes, from the phones built in browser, I can connect to the built in bigpond service, ( WHICH I DON'T BLOODY WANT).
    I can connect, and can surf
    I can't get the phones inbuilt Modem to activate, from my laptop.
    The laptop can see the modem, and can querey the Modem OK. The modem won't activate and dial out any where
    Max
    President:
  • 1,944 Answers
Could you please tell me who is your network ooperator? What program are you using to connect the phone to your PC? Thanks.
Posted on Feb 29, 2008
  • 1 more comment
  • Damen Wong
    Damen Wong Feb 29, 2008
    Thank you for all the info. Is you line data enabled?
  • Damen Wong
    What happens when you try to dial to the other phone number?
  • Damen Wong
    Do you have internet access from your phone itself (from your phone's built in browser)?
Asrock g31 m motherboard will only post if only one ram slot occupied , will not post if both slots are used , identical matched pair of ram ddr 667 800 mhz crucial ballistix both tested in another ri
I did some research. You didn't say what density the RAM was, but everything I can find on the Ballistix 800 MHZ DDR2 states that it runs at 2.2V. The standard for DDR2 RAM is 1.8V. You motherboard has both and AUTO and manual setting capability for memory (DRAM) voltage. It is possible that the AUTOP feature is not detecting the need for 2.2V, and that with only one DIMM installled, the memory marginally functions, but with the extra loading of the second it will not. Boot the system with the single DIMM, go to the BIOS, and set the DRAM voltage manually to the 2.01V setting (Verify by the part number of the RAM with the CRUCIAL website that is uses 2.2V before doing this). Once you have changed the voltage in BIOS, shut down and add the second DIMM and see if things improve.
Jan 16, 2012 | Asrock G31M-S Motherboard
Hello, I want to replace Pentium Dual core processor with Intel Core 2 Duo on Asus F5RL laptop. Can i directly replace it or What are the precautions should be consider before doing that. My laptop...
Good Day,
In your notebook configuration, you have Intel® Pentium® Processor T2370
(1M Cache, 1.73 GHz, 533 MHz FSB) and this processor model is on socket PPGA478.
The one you are targeting to replace to is
Intel® Core™2 Duo Processor T5500
(2M Cache, 1.66 GHz, 667 MHz FSB that is on both PPGA479 and PPGA478
so if you want to replace your current processor, just be sure to see if the socket models are the same with the old processor, for other socket number wont physically fit on your old socket.
Also be sure to have enough to knowledge and skill to perform the dismantle of the notebook itself.
ElectroStatic Discharge (ESD) is the term used to describe the transfer of static electricity from one object to another, and this is not good for the parts inside your note book.
Hope this helps, and thank you for using Fixya.
Another thing is to have an anti-static wrist strap to ensure no static related event can occur to your hardware.
Jul 10, 2011 | ASUS F5RL-X2 Notebook
Mother board 533 prescoot how the accpet ram and processer
This motherboard supports DDR2-800/667/533 Memory and any socket LGA775 CPU such as Intel Core 2 Quad, Core 2 Extreme, Core 2 Duo, Pentium XE, Pentium D, Pentium 4, and Celeron LGA-775 CPUs
Feb 01, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Apr 12, 2010 | HP Pavilion dv1000 Notebook
System beeps after 10 seconds when i start my comp.
Probably overheating- try cleaning it out real good, recompound the CPU heatsink.
Apr 29, 2009 | ASUS Computers & Internet
Product comparison
deal 2 is definatly better, go for it
Oct 28, 2008 | Computers & Internet
CPU Upgrade on Toshiba L40-14H
i do not believe that cores are physically exchangeble for core 2's
Sep 23, 2008 | Computers & Internet
Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Oct 03, 2007 | ASUS P5S800-VM Motherboard
LG CU500 Cellular Phone Logo
91 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
