Question about Philips GoGear HDD1850 MP3 Player
Power button dosn't work
So the other day I tried to turn the mp3 player on, but just wouldn't turn on. I hooked it up to the computer, thinking the battery was dead. Well it looked like it was dead, and charged.
I started listening to it, and it seemed fine, until I wanted to pause my song. The button (which is the play/pause/power button) changed my song. And if I held it in.. it turned my sound up!
Does anyone know what might be wrong?
Also, I recently moved, and misplaced the stuff that came with it. Is there a warranty for the GoGear mp3 player, if so how long?
Any help would be appreciated!
  • 476 Answers
First thing to try would be a firmware restore.
If you don't have the original CD, you can download the Device Manager here:
http://www.p4c.philips.com/files/h/hdd1830_17/hdd1830_17_pal_eng.zip
Install & run the Philips Device Manager & select the repair / restore option, then follow the on-screen prompts.
This will format and re-flash the device firmware. Any tracks on the player will be lost.
Another cause of your problem could be a bad connection on the earphone socket. This is usually accompanied by low or poor sound, with no vocals.
Posted on Feb 29, 2008
2 Suggested Answers
  • 476 Answers
SOURCE: Philips GoGear mp3
Sounds like the files are DRM copy protected.
You can check for protected tracks.
  • In Windows Explorer, go to the folder where the tracks are stored on your PC.
  • Click on View -----> Details
  • Right click on the header bar in the right hand window and select protected. (If protected is not listed click on More)
  • Tracks will be listed with No or Yes under "protected". Check your non-playing tracks are listed as No, under "protected".
The HDD1830 is not compatible with protected files, although your PC will play them ok.
Posted on Mar 02, 2008
I just bought a GPX MP3 player (ML651B) I put music on it and was charging it. It now doesn't even want to turn on. I looked at the GPX website and I couldn't even find this one among their products. Now,...
The power button (more like a slide) on the bottom right side will turn it on once it's ejected from the computer. Hold the slide in, and let go after a second or two. Give it a few seconds (like 10) and it should power on. I got mine as a gift and am still working through the interface.
Nov 24, 2010 | GPX ML648B MP3 Player
Wont turn on... balck screen... when i hooked it up to my computer nothing happened... tried the lock button, power button, and the wheel... still nothing
Hi, I just learned here that you have to do TWO things to get it to turn on. One, make sure the slider is in the On position. Then press and hold the play button (top one on the wheel) for 3 seconds. Worked for me, when previously the only way I could get it to turn on was to hook it up to a power source (wall or USB), which sounds slightly different than you. Hope it works anyway!
Jan 02, 2010 | SanDisk Sansa Fuze MP3 Player
My mp3 player is not working after 3 days of using it
Hi, try replace the battery and if it doesn't still power on, it means it is hardware problem, you need to get to a technician to help fix the problem.
Compliments and wish you the best.
Jan 02, 2010 | Samsung YP-K3 MP3 Player
My NWD-B103 dosn´t turn it on, even if this is connected to the pc, it dosn´t reconize the divice.
First reset yours by the Back button;
If not solved;
Reset again by the button, the On the Computer by Fat32 Format, and then Copy the Initial Files that were on your MD when you Bought;
Good luck
Oct 28, 2009 | Sony Audio Players & Recorders
Won't turn on nor recharge
I think i have a solution to your problem. My MP3 did the exact same thing. Try hooking it up with a USB cable and wait a day or 2. Then check it again. Try turning it on and it might work. I'm pretty sure it should work. Good Luck mmdogsrus!
Jan 29, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Mp3 was working, then it stopped
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 22, 2008 | Audio Players & Recorders
MP3 Player no power
get a pin and press the little reset button in the back
May 10, 2008 | Coby MP-C7085 MP3 Player
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Aggravating MP3 Trouble
Sep 25, 2007 | RCA TH1101 MP3 Player
Won't power up
There could be due to a corrupted file, let us try to "Format" your device. Formatting will delete any existing corruptions in your MP3 player. To format your MP3 player, please do the following steps: Note: Formatting your MP3 player will delete all the files in your device, I suggest that you create a back-up copy of your files from your MP3 player to your computer. 1. Put the Hold switch ON, it's located at the side of the MP3 player (orange color should be visible). 2. Plug the MP3 player in your computer without the battery. 3. After it has been recognized by the computer, please open "My Computer". 4. Your device should appear as a "Removable drive" with an assigned Drive Letter (Ex: "D", "E" or "F"). 5. Right click on your Sansa MP3 player then select "Format". 6. On the format pop-up page, select "FAT" for the file system. 7. Click on ok/start. If you can't format your MP3 player at your computer. Please try it on a different computer. Note: If your MP3 player has a Firmware version 3.x and below please try the steps below: Also your MP3 player may have encountered temporary power loss. This issue usually happens when there is a failure of power going directly through the system of the MP3 player from the battery. Let's try to power-cycle your MP3 player. To power-cycle your MP3 player, please do the following steps: 1. Take the battery out of the player. 2. Hold the "Power/Menu" button for 30 seconds without the battery. 3. Try powering on the device. 4. Please try these steps for 3 times. I hope these steps help you resolve your problems regarding your SanDisk product. This is what sansa sent me when I had a similar problem. Good Luck!
Jun 05, 2007 | SanDisk Sansa m240 MP3 Player
Philips GoGear HDD1850 MP3 Player Logo
139 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
