Question about Lexmark X5650 ALL-IN-ONE PRINTER
I have a new all in one x5650 when I opened the box it had no setup instructions I have everything figured out except the fax (which is why I bought this one) I can't send a fax it keeps telling me phone line is busy but the computer isn't even on and nobody is on the phone. I need a manual
    Brigadier General:
  • 7,191 Answers
You can download the complete User guide and Fax Guide from the manufacturer's websiteby clicking this link
  • You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Feb 22, 2010
SOURCE:
We just bought the icess itransform is625 rc car for my son...the instructions were missing from the box...does anyone know how long the batteries need to be charged prior to first use? Anything else I...
instructions says 4-5 hrs with 5 minute cool down before use.
bluetooth pairing for car uses icess s625 with 0000 pin code.
downloaded icess app ver 5.0.0, everything seems to work except music volume and speed setting options. only max sound and speed.
Jul 04, 2014 | Toys
Lexmark X5650 says faxes in memory. Already went to another mode. How do I get faxes out of memory?
Once you navigate away from the fax mode when a fax message goes into memory, you will lose the message. If this happens again, try not to navigate away from the fax mode. The "fax in memory" message usually pops up when the printer's not able to continue printing the fax due to a very low ink level. Just open the printer (w/o navigating away from the fax mode) > replace the ink cartridges > close the cover > print the fax.
May 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
How do you load a lexmark X5650 all in one printer, copy, photo, scan, and fax? I am trying to figure out how to load the fax to send the fax to someone.
Sending a fax using the printer control panel:
  1. Make sure the printer is on and is connected to a working phone line.
  2. Load an original document faceup into the Automatic Document Feeder (ADF) or facedown on the
    scanner glass.
  3. From the printer control panel, press the Fax button.
  4. Enter a fax number, or press Address Book to select a number from the Speed Dial or Group Dial list.
  5. Press Color or Black to select a color or black-and-white fax.
  6. Press Start to send the fax job.
Source: Lexmark 5600-6600 Series Fax Guide
May 06, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
Cannot figure how to run a test page for FAX
Open the HP Solution Center then click on the "Settings" icon at the bottom of the window.
Look under the Fax settings area and click on the button that says "More Fax settings".
The last 2 options, "Test Fax Setup" and "Fax to PC Setup Wizard" should help you out in verifying your fax capabilities are setup correctly.
Jul 02, 2009 | Digital Products Hewlett Packard OfficeJet...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Lexmart X5650 Printer
Hi Charlotte,
All, off the cuff advise on this forum is free.
That being said, we tend to jump on the paid solutions first then get after the free ones during slow times. Therefor if you have time and are patient the free forum will do fine, if you are in a hurry or want to Chat live to a support tech like myself and work through the problem during a live chat(faster) it cost $19.99 but we will stay on the line unil we work through the troubles and get you up and running.
Lexmark does offer limited free support as well for their products but hold times can be long and depending on where you're from it may or may not be available.
As for starting you off, If you have found the ink cartridges in the packaging(usually stuffed into or taped to the foam). and followed the setup flyer that shows you how to remove the tape and power it up, then you can open the lid of the unit(including the scanner) and you should see two coloured carriers slide into the middle of the opening. Push down on them and they will open up. Then remove the cartridges from the foil packs and remove the tape from the copper section. Now slide them into the same colour carriers and close the lids.(link below will open a setup guide, then click on the "Setting Up The Printer" section and scroll down to page 17, it has pictues that should help).
once you've done this, pop the setup disk in the dvd drive on your computer and fllow the onscreen instructions. Don't plug in the USB cord until the program that pops up tells you to and you should be ok.
If you require more detailed assistance with this(ie Chat session), feel free to click on my name at the top of this solution, if I'm online and available the page it takes you to will have an "Ask Me" button under it, when you click it you will need to agree to pay the charges but I will be happy to walk you through in more detail.
Chris
May 12, 2009 | Lexmark X5650 All-in-One InkJet Printer
Didn´read the instructions
Unplug he USB and Power on your printer.
go into cotrol panel - then open the printers/fax folder.
Right click on your printer in question and select delete.
Install software and drivers from CD or download from lexmark website.
Shut down PC
plug in USB and Power to printer.
start PC and let it install using the drivers you just Downloaded.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 07, 2009 | Lexmark X5650 All-in-One InkJet Printer
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
I lost the Lexmark X5650 Printer, Scanner, Copier and Fax CD, What can I do?
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Mar 05, 2009 | Lexmark X7350 All-In-One Printer
Lexmark X5650 ALL-IN-ONE PRINTER Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
