Question about Microwave Ovens
Beep sound at the touch of buttons has become very slow. pl help
  • bjj1214 Oct 10, 2008
    I have a GE Spacemaker Microwave Oven - JVM1410 - that has no "Beeper Volume Button." How do I shut the sound off? It wakes the entire house up when trying to do anything with pushing buttons on the unit! HELP!
  • sarbendub Dec 14, 2008
    how to use temp controll in my magicook galaxy?
How to use temperature control for cooking
Posted on Feb 29, 2008
My Oster Microwave #OM1201EOVG beeps when plugged in and will not stop. Just beeps continually. Is it broke?
probably bad touch pad, the unit thinks your standing there pushing and holding down a button on the touch pad. Will need new touch pad or main PC board. Tough pad cheaper, more common, start there.
Oct 06, 2017 | Oster Microwave Ovens
My Samsung microwave was giving SE error. I cleaned the contacts. Now it is showing E1 error with constant beep. Pl suggest remedial action.
Constant beep sounds like a bad microprocessor on the main time board. May have to replace the board.
Sep 24, 2017 | Samsung Microwave Ovens
Oh my rival microwave if I push a minute express cook and then push the power button and it says PL 10 what does that mean
Power Level 10, that's the highest power. You don't have to push the power level button every time you use it, just press the minute express button, then touch the start button
Feb 25, 2015 | Rival Microwave Ovens
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
Suddenly the beep volume is almost mute- how to bring the volume back up?
You will most lokely need to replace the "beeper" as its components have become worn ut with time
Oct 03, 2014 | Sanyo Microwave Ovens
How do I get the microwave to stop beeping.It"s beeping and locking the controls by itself.
The touch pad sounds like it is trying to tell you it has a stuck pad. The touch pad will need replacing.
Oct 01, 2014 | GE Microwave Ovens
Microwave model no.NN-C2003S beep sound has become low.Please provide remedy
Try a reset by:
- unplugging power for a minute
- plugging it back in
- setting the clock
- trying it again
If that does not fix it, see your owner's manual to see if it can be adjusted (usually not).
If you still have trouble, you should call for service.
Jan 08, 2013 | Microwave Ovens
MICROWAVE BUTTONS WILL NOT RESPOND TO ANY ACTION. IS THE MICROWAVE LOCKED.
Hi and welcome to Fixya, I am Kelly. This is usually from the Child lock being activated: 1. Touch STOP/CLEAR.
2. Touch and hold START/ENTER more than 4 seconds.
LOCKED will disappear and two beeps will sound.
Thanks for choosing FixYa, Kelly
Mar 26, 2011 | LG LMVM2055 Convection/Microwave Oven
Time showing on panel. No functions work.when I touch any button,
You can try to reseat the serial ribbon but it sounds like a board problem. to reseat the ribbon, unplug unit. remove the case for counter top models, otr models need to remove the grille, and the control panel screw, lift up and pull out at the top. the serial ribbon is a flat set of wires at the top of the board lift on the connector latch to loosen the ribbon pull it out, push it back in and relatch. close up the control panel before plugging back in. if it works great, if not it is time for a new microwave boards are very expensive.
Jun 19, 2009 | Microwave Ovens
The beeps have become inaudible.
The beeper sound level can be adjusted. Press the BEEPER VOLUME button, then choose 0–3 for mute, medium or loud.
If that doesn't work, unplug the oven a few minutes, plug it back in, then try again.
If you don't have your owner's manual you can find and download one here:
http://www.geappliances.com/service_and_support/literature/
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 22, 2008 | GE JVM1651 Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
