Question about Fisher Refrigerators
Butter warmer problem
Upside down fridge freezer Model N5008
Butter warmer no longer operates, any suggestions how to get at it to check.
The problem for Butter warmer not working was as I suspected the internal workings of the regulator slider that adjusts the temp for the butter warmer it's self. The regulator intenals get a sort of burnt ember on them from something similar to a couple of positive and negative wires connecting causing a sorf of short. I have an electrical tech nearby who opened up the regulator to find and use a small wire brush and scraper removed the burnt on gum. It returned the warmer to working immediately upon re-installation and is still several years later, working a treat.
I am disappointed to note that in stores we have checked to upgrade our fridge all say that no models have the butter warmer anymore. Hence we are holding on to our fridge.
Posted on Nov 21, 2010
I have the samsung upside down fridge 590 litre freezer is great but the fridge is showing it is set on 3 degrees but inside the fridge it is 7
For starters, Get a second thermometer to check against those two.
Also leave the freezer closed to several hours and see what the difference is in temp.
I would expect that the inside temp would mostly be warmer than the 'set' temp., as the latter is always trying to catch up every time the freezer door opens.
Oct 24, 2013 | Samsung Refrigerators
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
Hello. My fridge freezer is playing up. It's from John Lewis and is about 4 years old. The fridge was not reaching the right temperature and it was making a funny noise, so took it apart and found that...
most fridge-freezers send cold air from the freezer to cool the fridge. the flow is usually controlled by adjusting a 'warmer-cooler bar or wheel in the fridge. maybe you disturbed its original position while working on the fan.
Jun 19, 2017 | Refrigerators
Westinghouse Upside down Fridge Freezer Model #BJ504T-R5. Fridge will not go cold, cannot have a a Cold Beer out of it. Any suggestions on how to fix this problem? Freezer works OK
put the beer in the freezer for 30 mins,that should cool it nicely.....
oh, the fridge aint working, sorry,poss the thermostat or (still thinking about drinking warm beer, ugh...)have you tried cleaning the vents...
Aug 18, 2010 | Refrigerators
Defrost cycle on my elecrtolux ER 7926/1 B fridge freezer seem to be to long and temperature in the freezer drops down to 0 C every defrost cycle, does enyone have a wiring diagram for this model please
No i dont but i could suggest you check the heating element and the clixon that connects to the evaporator. If the heater does not function, it takes a much longer time than usual to switch the freezer on.
Sep 21, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Mini Danby Fridge Won't cool but compresser is running very HOT!(Model DCR412BLS) the fridge has just recently been moved into a warmer environment without air conditioning. As well, it had accumulated...
never turn a fridge up side down and when moving a fridge or freezer keep it upright as much as poss and dont plug back in for 24hrs.now leave it unplugged a buy new one...
Sep 14, 2009 | Danby DCR412 Compact Refrigerator
Fridge and freezer too warm after cleaning
I guess by now you have resolved this.. If you need help please alert me..
If this is unresolved, can you tell me if the compressor runs? According to the Jen air manual I downloaded, you shud be able hear a number of sounds from the fridge, at different stages eg defrost, cooling etc. Obviously you checked the temperature controlls? Door seals Ok? Power,is the light on.. Even if there appears to be power, pls change the power outlet and run the fridge from a different source. Pls advise if you still have problems. Rgds,
May 01, 2008 | Jenn-Air JCD2389G Side by Side...
Very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Feb 16, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Refrigerators Logo
165 people viewed this question
Top Fisher Refrigerators Experts
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
John Tripp
John Tripp
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
