Laptop doesn't switch on
Acer Aspire 3614 Laptop. Had broken power socket pin, replaced socket, laptop now charges but doesn't switch on (power light flickers then goes out but laptop never comes on).
  • 100 Answers
U remove backside battery and connect power connection.Switch on ur laptop power button and check it.whether it is battery problem or ur laptop problem.
Thanks
Posted on Feb 29, 2008
Model: Acer Aspire E1-571 The battery had
The battery may have failed even though new.
Apr 24, 2017 | Acer Aspire E1-571-6650 Laptop
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
CHARGING POINT BROKEN ON ACER ASPIRE
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 08, 2012 | Acer Aspire 5551 Notebook
Please post the step by step process of turning on my laptop acer 5570z.. (powerswitch problem) thanks in advance and more power
Hi
Have you plugged in your power cord to the electric socket so that you can charge the battery
using the laptop with the power cord in while it is charging
so if there is not charge in the laptop at all maybe plug in and turn on socket switch
and leave to charge for an hour or so
then try to start laptop again
hope you can sort it
good luck
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
Nov 19, 2009 | Acer Aspire 6920 Notebook PC
MY acer aspire 3680 not powering on. The light on the power cord is on but the light at the front of the laptop is not showing. I took out the battery and replaced it no differennce. I held down the power...
When you wriggle the plug in the power socket on the laptop and the charge LED flashes and in the right position it charges, this indicates that the power socket is faulty or there is a dry solder joint on the motherboard where this power socket is attached.
To get at the power socket will require dismantling the laptop completely.
If you are confident, can dismantle, reassemble a laptop and use a temperture controlled solder iron then try and fix it. If not a computer repair shop can do the repair, I suggest you get a quote first.
Aug 26, 2009 | Acer Aspire 3680 Laptop
My acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
My sister has a new acer aspire 5220 laptop, and it was working, but now it will not come on, the ac power light is on but the power button when pressed will not come on.
check this site it will helps u to solve ur problem
http://www.laptoprepair.co.uk/how-to-repair-laptop-broken-power-socket-connector-pin.htm
Sep 06, 2008 | Computers & Internet
Acer 3680 ac pin broken
That's really not advisable. At our shop we do socket repairs, I suggest finding someone local who specialises in laptops and asking them to replace it. You can get the sockets on e-bay, etc, if you wish to try it at home, though I don't advise it.
Don't forget to take static safety precautions!
Aug 19, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
81 people viewed this question
Alun Cox
David Payne
David Payne
