Windows doesn't recognize new SATA DVD-RW drive. It has a ? in the Device Manager window in XP, but i cannot find the correct .inf file to satisfy it.
    Genius:
  • 1,142 Answers
You need to do few things
1. reset the bios so that it starts detecting the drive
2. right click on the option with yellow ? and select uninstall and restart your system
3. remove the upper and lower filters from registry
the path for the same is
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
try booting through this drive using a bootable cd just to check if its not an issue with the DVD RW
i hope these steps help
please let me know in case it does'nt so that i check for further possibilities
Posted on Feb 29, 2008
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
Mon lecteur est en panne je veux le changer
You can change the dvd rom by opening the computer case and taking out the sata cable and power cable.
you can replace it with any SATA DVD+/-RW SATA Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
Windows XP, Vista and 7 will automatically install the new DVD drive for you.
Vous pouvez modifier le DVD-ROM en ouvrant le boîtier de l'ordinateur et en tenant le câble SATA et câble d'alimentation.
vous pouvez la remplacer par n'importe quel DVD SATA + /-RW SATA Drive
Windows XP, Vista et 7 installera automatiquement le nouveau lecteur DVD pour vous
Mar 01, 2011 | Sony Optiarc AD7240S DVD?±RW (?±R DL) ...
My webcam is not recognized and I get a message that says that the camera is not turned on. I cannot find the device in my device manager in order to repair it and the driver. I need help! I can be...
You should first verify that the USB port can recognize a USB memory stick i.e. verify that the USB port hardware is working. If its is not, use Device Manager to reload the USB Host Adapter drivers.
If this is an external USB device (laptop or desktop) ...
the Device Manager will always locate the camera, if only as an Other Device or sometimes with the wrong driver in another device class. One possibility, if the host PC is a laptop, is check the Power Scheme. Set this to Always On, as this is supposed to (but not always..) stop Windows from turning off external interfaces (such as USB) to conserve power.
Check if the camera will appear in Device Manager on another PC. This will verify that the camera hardware is functional.
If this is a laptop built-in WebCam, it will usually appear in Device Manager under Imaging Devices. If it does not, I'd suspect that the camera hardware has a problem.
Let's assume that this is an external USB Camera. When the camera driver is loaded, the driver INF file is copied to a new file
C:\Windows\inf\oem.inf where is an arbitrary number.
When you plug in the camera, Windows PlugandPlay looks in C:\Windows\inf for the correct driver to assign to the device.
Windows can get confused about drivers, esspecially if you have attempted to reload the driver, or load a newer version.
If you do a search for all C:\Windows\inf\oem*.inf containing "Toshiba" or "WebCam" you should be able to locate one or more oem*.inf files that is the installed driver for your webcam.
Lets say this file is oem31.inf Delete this file and also oem31.pnf if its present.
This removes the last driver that was installed. Now, run Device Manager, and plug in the camera. If Device Manager can locate the camera (as an Other Device to start with), you should be able to reload the correct driver, either from the installed driver directory (if there is one) or from you camera CD.
Jan 03, 2011 | Toshiba Computers & Internet
My vista does nnot recognize one partition on my
1. In the run command (Start menu bar) type "regedit" to bring up the Registry Editor.
2. In Registry Editor, navigate to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion
3. In the details pane, double-click DevicePath.
4. Add a semi-colon to end of the existing text, and then add the path to %SystemRoot%\System32. The result should be similar to: %SystemRoot%\inf;%SystemRoot%\System32
Do not remove the %SystemRoot%\inf file path from the DevicePath registry entry.
5. Click OK to save the new value, and then close Registry Editor.
6. Delete “INFCACH.1” FROM C:\Windows and C:\Windows\Inf Directories (if it exists)
7. Ensure that there is a copy of the usbstor.inf file in C:\Windows\Inf
If there isn’t – follow the below steps:
a) From another Vista system (copy it out of another Vista system and copy it directly into the C:\Windows\inf directory
OR
b) From the problem machine, run Command Prompt ( as administrator). From C:\ do a dir usbstor.inf /s . Wherever the file is found, go to that directory and copy all the files located in that directory to C:\Windows\inf directory
8. Open device manager, uninstall all unknown devices (right click, uninstall) so they all disappear from the list
9. Reboot the computer
10. Plug the device in (the drivers will now install and the device will be usable!)
Mar 06, 2010 | Electronics - Others
SATA / Optical Drive Not Recognized
In my travels through this nightmare called Windows, there have been some real issues. I ran into this same problem with XP with SP3, What I did was set up a virtual machine running Vista Premium and loaded the SATA Optical with the Vista OS which recognized it right off. I was able to use the drive just fine when using the Vista in the virtual machine but was not seen in XP. Have not found a decent work around this....just waiting for Windows 7 to come out so I dump both XP and Vista and start over learning another new curb, but at least I've been told that a huge amount of drivers are to be loaded into the new OS...we'll see.
Sep 18, 2009 | Intel Computers & Internet
When in ''MY COMPUTER'' - CD Drive (E:) was droped into DVD-RW (D:
Try uninstalling the drivers in device manager, shut down, reboot and Windows should find both devices, it might ask for your windows disk to install drivers or search online to install them
Jul 27, 2009 | Computers & Internet
Transcend connection
For all of you who are unable to make USB drives work or still are getting the “USB Device not recognized”, try this method.
Download usbstor.inf and usbstor.pnf files (links are below) and copy them to
C:\ windows\inf  folder.
(click yes to overwrite the files if windows asks)
Remove the Unknown device from the Device Manager - Other Devices.
Inserted the USB drive and lo and behold! It should be recognized in a jify!
usbstor.inf and usbstor.pnf can be downloaded from here:
http://www.infdump.com/download-inf-files_new.php/inffiles/U/USBSTOR.INF/5.1.2600.0/download.html
http://www.pnfdump.com/download-pnf-files.php/pnffiles/U/usbstor.PNF/download.html
Hope this helps for everyone whose USB drives are still not recognized.
Regards,
Deboo
Jan 22, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Windows XP boots endless if SATA is set to AHCI
this is'nt so easy here an example solution:
Enabling SATA mode to AHCI after XP Install (applicable to most laptops, or systems) If you want to enable SATA mode as AHCI after installing Windows XP, then read on. It's a bit of a long read because of step-by-step instructions, but worth it.
I did this on on Acer Aspire 5315-2153, it seems like the basic strategy should work on other laptops or systems.
For whatever reason, you may have installed Windows XP on your new laptops with SATA Native Mode disabled in the BIOS. Once XP is installed, enabling it in the BIOS will result in a BSOD upon loading Windows because XP doesn't have the correct drivers.
I read that enabling SATA native mode will give you a slight performance inrease and slightly increased battery life, so it seems worthwhile to me smile.gif
Here's how I did it on a Acer Aspire 5315-2153 running Windows XP (32 Bit version):
- Download the Intel Matrix Storage Manager software from Intel (I think it's iata_enu.exe)or AHCI_Intel_v7.5.0.1017_XP.zip from Acer web site.
- Extract files from AHCI_Intel_v7.5.0.1017_XP.zip to e.g. C:\AHCI_Intel_v7_5_0_1017_XP files need: (you may delete the rest)
iaahci.cat
iaahci.inf
iastor.cat
iastor.inf
iastor.sys
TXTSSETUP.OEM
- Now go to Device Manager, under IDE ATA/ATAPI controllers you should
see: Intel 82801HEM/HBM SATA AHCI Storage Controller
- Right-Click on that and select Update Driver
- Say no to connecting to Windows Update to search, hit Next
- Select Install fro a list or specific location (Advanced), hit Next
- Select "Don't search. I will choose the driver to install", hit Next
- Select Have Disk
- Browse to C:\AHCI_Intel_v7_5_0_1017_XP and highlight the iastor.inf file, hit Open
- Select OK
- Now you should have a list of controllers, for the Acer 5315-2153 choose Intel 82801HEM/HBM SATA AHCI Storage Controller, hit Next
- You'll get warned that installing the device driver is not recommended, click Yes to continue installing
- Click Finish
- Click Yes to restart your computer
When your computer boots up, you need to hit F2 to enter the BIOS. Change SATA mode to AHCI, save changes and exit.
After you log into Windows, your computer will find the "new" hardware. Wait until you get the popup message to restart your computer, say Yes to restart one last time.
You may download also from Intel the RAID/AHCI Software - Intel® Matrix Storage Manager (iata70_enu.exe 5640KB) and install it in your system, it may fix in case you got the wrong Intel 82801 AHCI controller.
I give credit to Jamie Rybarczyk at HP Business Support Center forum for doing most of typing.
http://forum.notebookreview.com/showthread.php?t=186471
Jan 06, 2009 | Computers & Internet
Olympus 3000 Zoom digital camera
You have to edit the file:
c:\windows\inf\srusbusd.inf
You'll have to remove two semicolons.
The section:
[Manufacturer]
;%MfgNikon%=ModelsNikon
;%MfgEpson%=ModelsEpson
remove this semicolon=>;%MfgOlympus%=ModelsOlympus
Must become:
[Manufacturer]
And
The section:
[ModelsOlympus]
remove this semicolon=>;%USB\VID_07B4&PID_0100.Device%=Olympus,
must become:
[ModelsOlympus]
%USB\VID_07B4&PID_0100.Device%=Olympus, USB\VID_07B4&PID_0100
After this, if you have already the Olympus C-xxxx in your Device Manager,
uninstall it and run again the new hardware wizard. Let Windows XP find the
correct driver. Windows will attempt to frighten you with a catastrophe
prophecy. Just ignore it and go on (it works perfectly).
You're done. Now your Windows XP will see your Olympus C-XXXX Zoom
without any additional software.
Jun 05, 2008 | Olympus C-3000 Zoom Digital Camera
Computers & Internet Logo
425 people viewed this question
Alun Cox
David Payne
David Payne
