Windows doesn't see SATA DVD-RW drive - Computers & Internet
  • hifidave Mar 17, 2008
    I discovered the problem was with my registry settings. The microsoft site had a troubleshooter that fixed the bad registry setting, and it works wonderfully now.
  • 55 Answers
I think the problem is about the mother board , normally the sata sistem is read by the utility disc that puts a specials software. sata
is a new sistem for windows xp - if you have the utility disc can you
run it normally is made by boards of asus in this way you have to
generate a floppy for starting sata sistem. i hope you will check in this way- delfo
Posted on Mar 11, 2008
  • 112 Answers
Hi Dave.
What version of windows are you running?
Posted on Feb 29, 2008
  • Geoff Champion
    Geoff Champion Mar 14, 2008
    SATA runs on Vista Xo Win 2000 win 98.
    Has your motherboard got the SATA controller onboard or is it a seperate card.
    Let me know the type of controller and type of OS to help you more.
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
My Pioneer DVD-RW 109 ATA does not show in computer list with windows 7, any ideas
Do you mean that it doesn't show in the "My computer" section?
Did you install this yourself? Or did it come with the computer.
If you did it yourself, you may have to check that the cords are properly connected. Also, if you are adding it as an additional drive, you may have to enable the SATA connector it's connected through the BIOS. Like SATA-0 may be your HDD, SATA-1 may be your primary DVD Drive, and if it's an additional one SATA-2 might be that one.
Thanks,
Please Rate.
Jul 08, 2011 | Computers & Internet
Mon lecteur est en panne je veux le changer
You can change the dvd rom by opening the computer case and taking out the sata cable and power cable.
you can replace it with any SATA DVD+/-RW SATA Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
Windows XP, Vista and 7 will automatically install the new DVD drive for you.
Vous pouvez modifier le DVD-ROM en ouvrant le boîtier de l'ordinateur et en tenant le câble SATA et câble d'alimentation.
vous pouvez la remplacer par n'importe quel DVD SATA + /-RW SATA Drive
Windows XP, Vista et 7 installera automatiquement le nouveau lecteur DVD pour vous
Mar 01, 2011 | Sony Optiarc AD7240S DVD?±RW (?±R DL) ...
I have a Compaq SR1650NX (Windows XP Media Center with MS Office 2003) computer. My DVD+RW will not open. I can open it manually but my computer does not recognize the DVD. If I change out the DVD+RW,...
There is nothing wrong if you want to replace it with generic or branded DVDrom drive. As long as compatible with your motherboard. If you are using IDE or UDMA cable you must buy IDE DVDrom drive but if it's SATA cable you have to buy SATA DVDrom drive.Good Luck
Nov 26, 2010 | Computers & Internet
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    SATA dvd writer doesnt works with D101GGC
    you have another sta device conected in your pc?
    go to the bios to see sata configuration chip.
    i think there is to resolve your problem
    Apr 07, 2009 | Intel D101GGC Motherboard
    DVD/RW Drive
    what else you have on the pc???
    sound like you have too many attachment. try to go into the BIOS and see if there any setting you foregot to set.
    Oct 10, 2008 | Computers & Internet
    My dvd rw is not detected
    Sounds like you need your manufacturer's SATA drivers.
    This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
    If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
    This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
    Aug 20, 2008 | Microsoft Windows XP Professional With...
    Sata DVD Ausus using K8V-MX
    TRy to load the "optimized bios default setting" in your bios setup. If not solve the problem maybe in your windows issue.
    try to boot up windows in safe mode and then start it normally and let the windows fixed the problem on it.
    if still problem exist maybe you need to repair your windows installation using the new SATA DVD to resolve problem regarding the issue. or reinstall it. (Note: important files was no guarantee to retain, backup files when doing this).
    note:
    Jan 06, 2008 | ASUS K8V-MX Motherboard
    Computers & Internet Logo
    59 people viewed this question
    David Payne
    David Payne
