Question about Rio DVR4100 DVD Player/VCR
DVD Rubber Band for Load/Eject
I've been having problems loading and getting the dvd to raise and play. Also ejecting is a pain. Well, I took it all apart and the rubber band seems to have a lot of slack in it. When I made a figure 8 with it it pulled it right up no problem. Just needed a bit of tension. But it wond go backwards and eject. Where can I find a replacement rubber band??????
  • teamsdsu Feb 29, 2008
    try a office depot!
  • 749 Answers
Electronic shop, who sell electronic parts, have it! just bring to then the rubber belt. see to it that the rubber you're buying is a bit smaller (in diameter, about 2-3mm. smaller). goodluck.... check its thickness too.
Posted on Feb 29, 2008
  • Rommel Balcita Mar 01, 2008
    that's right, they may have a spare parts there.
  • Neil Shaw
    Neil Shaw Jun 26, 2018
    Excellent service....thank you.
I have a dvd stuck in the slot. It won't play or eject. I hear the tv trying to eject but nothing happens. How can I fix it?
You will need to open up both dvd case and dvd player! the rubber type band that turns the wheels to open tray is bad, not tight enough to turn wheels! This rubber type band is located at the front of tray. you might be able to get tray to open by taping the top front of player after you push eject, just not hard enough to bend case.
Mar 25, 2016 | Televison & Video
Have a Dual Multimedia Reciever everything works fine but dvd won't eject. What can I do to get it to eject?
Most DVD eject system are powered by a small rubber band that can break or just fall off. Going inside the unit will reveal if it has.
Jun 13, 2015 | Dual Computers & Internet
DVD won't eject
Manually pull the door open. If you can see the motor spinning in there it may have a rubber "band" that looks like and O-ring. If that is broken then it can be replaced but it is a difficult manuver with a screwdriver. They tend to dry rot like all rubber parts and fail...
Feb 23, 2012 | Sharp LC22DV24U 22 in. LCD TV/DVD Combo
I have a Sony DVD/CD Rewritable drive that tries to eject but doesn't. It is model # DW-D22A. Is this a problem I might be able to fix or would I be better off getting a new drive?
It may have a jam, there is a small pin hole under the tray usually on the right side.. straighten out a paper click and press it in there with some force. This is the manual eject. See if it resumes normal operation after that.
Jun 28, 2011 | Sony DW-D22A DVD±RW Dual Layer Burner
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
CAnt eject DVD disc. Get message ''blocked'' Machine will play the DVD but when I try to eject nothing happens other than the message. What size lump hammer should I use?
if you want to just get the disc out there should be a tiny hole on the front of the drive where you can insert a paper clip firmly to eject the drive.
I would also check the rubber band / cogs by taking a look inside and see if there are any issues.
Also if you reboot do you get the same problem ?
Apr 13, 2009 | Televison & Video
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Jan 30, 2008 | Televison & Video
DVD will not eject the tray
Open up the unit find the load and unload motor on the DVD carriage and turn it manually and this should eject the tray. You may even have to unscrew the carriage to get to the bottom of it to access the load and unload motor.
Jun 21, 2007 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Rio DVR4100 DVD Player/VCR Logo
671 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
Jaime Hernandez
JOHN TOPLISS
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
