Question about Acer Aspire 5100 Notebook
Problem with battery or motherrboard?
Hello there,
I have an acer 5100 laptop and its almost one and a half years old. From few weeks before my laptop suddenly turns off even when it is connected with power supply. When it goes off the light whichh shows "battery is charging" also goes off which makes me thinmk that there is a problem with the battery connection. Can anyone please help!!
  • 3 more comments
  • adnanrulz Feb 29, 2008
    with no battery? i didnt chek to be truthful....i will let u know....
  • adnanrulz Mar 02, 2008
    yep...even without the battery!!! Any solution guyz? thanks
  • adnanrulz Mar 04, 2008
    could the problem be heat? The laptop heats up a lot and then closes.
    thanks...i will try that...
  • adnanrulz Mar 06, 2008
    thanks..its awesome...its working...thnx a lot 4 da help....
    Genius:
  • 3,587 Answers
Ok..first thing..does it run ok with no battery on mains power?
Posted on Feb 29, 2008
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Feb 29, 2008
    that's one way to isolate the issue..
  • Patrick Michaels
    Patrick Michaels Mar 02, 2008
    nope..it's most likely inside in motherboard, where that function resides...
    could be time for a motherboard swap, which is not unlike doing heart surgery
  • Patrick Michaels
    Patrick Michaels Mar 04, 2008
    sure...that would make sense..the battery needs to be stood up on it's smaller side, so that the heat will dissipate, and the laptop should be raised at least 4 inches, on one of those products that provides air under the computer.
    check your computer warranty here 4 FREE
  • Patrick Michaels
    Patrick Michaels Mar 05, 2008
    thanks for using Fixya
My acer aspire one mini laptop won't turn on when i charge it. the orange light does'nt come on and i last used it about a week ago,and it hibernated because of low battery. iv'e had my laptop for about...
Remove the main battery and power supply charger adapter from the laptop, wait a few minute to get rid of any residual charge, now install the battery, power up! if no change remove battery, next plug the power supply back in, power on, if yes! the main battery is bad and needs replacement. If no change reply to this message so I can help you further. If you having low memory issues, the ram needs to be upgraded.
Jan 12, 2011 | Acer Aspire One Netbook 8.9" Notebook
How do i check battery
Special equipment is necessary to check the battery of a laptop computer. The equipment will test the charging ability as well as the performance of the battery under the standard "load" of operating the computer. If yours is no longer holding a charge, or the charge lasts only a short period, it's very likely that the battery is simply worn out. Typically expect that if a battery is more than 2 years old, you'll be running out of life for it. Some batteries last longer, some much shorter. For example, Toshiba's Tecra series batteries seem to wear out and drain their charge quickly after about 6-12 months, needing a new battery.
If the battery is less than a year old, the manufacturers warranty may stipulate free replacement.
The Acer Aspire 5100 has been out since 2006. If yours is an older model, it may simply be time to replace the battery. You may find a local computer repair shop that will test your battery for free since it's very simple for them to do.
Hope this helps, good luck!
Jan 12, 2010 | Acer Aspire 5100 Notebook
Low Battery life on Acer Aspire
I would first make sure that the AC is working. If the computer works on AC then it should be fine. I have had several batteries that lasted only a year. If you leave it plugged in all the time, that will do it. It is best to charge it and then use it on battery several times a week. Hope this helps some :>)
Jul 10, 2009 | Computers & Internet
Have three vertical lines on my laptop Acer Aspire 3000
This problem is possibly due to blown diodes in the LCD panel.
Apr 19, 2009 | Compaq Presario M2000 Notebook
Acer aspire 5100 won't stay on when booting on battery
replace the battery. Batteries usually only last about two years and it sounds like it just cant hold any more juice. To find a battery go to google.com and type in the model of computer and push search. Sorry for the news but its an easy fix
Dec 30, 2008 | Acer Aspire 5100 Notebook
Battery drains
This is most likely a bad battery. The battery has a built in discharge circuit that keeps the battery from draining when the machine is off. I'd say the this has malfunctioned, and that a new battery will fix the problem. Let me know.
Jul 29, 2008 | Acer Aspire 5100 Notebook
Frozen mouse and keyboard on acer 3100 notebook
acer notebook- froozen keyboard and touch pad.......any help
Jul 01, 2008 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 clock keeps falling behind...
if the clock is consistently being resetted then most likely you have a failing cmos battery. you need to dismantle the laptop in order to have access to the cmos battery. you need to fina a COIN type battery.
Apr 12, 2008 | Acer Aspire 5100 Notebook
ACER 5100 Laptop Problem
Appears to be Hardware-Related dilemma. Contact Service Station.
Sahaja Yoga is the Mahaa Yoga and is the Only Solution to all the Problems of World.
Apr 03, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
