Teac SD-B420 is not working. You plug it in and the red and green lights come on at the front of box. Pressing buttons on the box and remote results in nothing. Can you help please. Thankyou
I had same problem and fixed it by changing C7 capacitor on the board.
make sure the replacement cap is the same specs as the orig.
Posted on Aug 22, 2008
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
I have 3 wii remotes was using one that had batteries it died so i replaced all remotes with new batteries and now none of them will sync or work they just turn off right away
After replacing the batteries, you may have to do a hard sync by pressing the sync button beside the SD slot on the Wii and the sync button on the back of the Wiimote underneath the battery cover. Both buttons are a kind of dark reddish-brown colour.
Mar 25, 2011 | Nintendo Wii Console
My remote for maine box will not work # 2 is ok and works fine
Hi, my name is Cheri Torres with DISH Network customerservice. I came across your post and wanted to see if I could help. If yourDISH Network TV1 remote is no longer functioning properly the first thing youare going to want to check is the batteries. Make sure you have fresh batteriesin your remote; you can also take them out and reinsert them to make sure theyare in the remote properly. If you have already made sure the batteries arefresh the next thing to check is that all the mode lights (i.e. SAT, AUX, TVetc.) are lighting up red or green when you press buttons. Sometimes on DISHNetwork remotes none of the lights will light up at the top of your remote ifthis is the case with your remote you are going to need a replacement. In orderto get a replacement remote you can either call DISH Network at 1-800-333-3474or you can email me your account information such as account number and name onaccount and I can get a replacement sent out for you. In the case that yourremote mode lights are lighting up fine you will need to readdress your remoteto your DISH Network receiver box. I will list the steps here for you onreaddressing your remote. If you have any further questions or concerns feelfree to post back here or email me at Cheri.Torres@DISHNetwork.com. :)
Readdressing remote to receiver box
  1. Go to System Info screen. You can do this by either pressing the system info button on the front of your receiver box or by pressing the power button then the channel up button on the front of the DISH Network receiver box. You may need to open a little door on the front right side of the receiver box to locate the buttons. If both options fail, you can open the little door on the front left side of the box and pull out the smart card. You do not need to reinsert the smart card until you have finished all steps.
  2. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2). For your particular case you would need to locate primary remote address number which should be in a little white square.
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something other then what is already listed.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record three times. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Jan 09, 2011 | DISH Network IR Remote Control
How to connect remote
where the batteries go on the back of the remote there is a red round button press that while pressing the red button on the front of the wii behind a flip out piece of plastic which also has the sd card behind it. Hold them both down until the one blue light pops up on the wii remote
Jan 01, 2011 | Nintendo Wii Console
The wii console is not recognizeing the remote. Batteries are working fine. Theblue lights light up. None of the buttons are stiff or overly loose. Brand new remote
try and calibrate the remotes by pressing the red button on the console(its next to the sd card slot) and press the red button on the remote which is were the batteries are
Jun 06, 2010 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
Remote control for teac set top box HDB842 will not work .
I had the same problem and tried new batteries with no success until I had a close look at the terminals. One of the +ve terminals was rusted (Ithink a drink spill, hastilly wiped off). After restoring this terminal everything is now OK. Hope this helps.
Dec 26, 2008 | Televison & Video
Sky box wont work
try taking the plug out and waiting for 5 mins before plugging it in again.
Also are you pressing the button itself or just the remote control? The batteries in your remote might need replacing
Oct 27, 2008 | Audio Players & Recorders
Bush digital terrestrial receiver dfta 11
Hi John
If you havent allready try unpluging the unit from the mains.
Leave out for 5 mins then plug back out & allow system to reboot.
Cant guarantee this will work but it does solve a lot of digi box problems.
http://dysonmanuals.llc.nu/
Chris.
Mar 09, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
