Question about Panasonic Toughbook 50 Notebook
Hard drive error
My toughbook has shut down. It says something about a hard error. The hard drive sounds like it is making a wierd noise. The screen turns on, but i am unable to get it to boot, even in Safe Mode.
i tried swapping the hard drive with another toughbook and it does the same thing. I'm guessing that the hard drive itself is somehow damaged or the connection from the hard drive to the computer is failing.
Any help on how to recover the info on the hard drive would be helpful.
thanks
    Novelist:
  • 113 Answers
You need an adapter is the hard drive is IDE, but not if it's Sata. You can probably connect it internally to almost any desktop computer, and then copy the data to a flash drive or other medium.
I can help you with the technicalities, but you'll have to find a friend who has a computer you can "borrow".
Alternatively, you can probably find a local computer shop that can provide this as a service, though you'd certainly have to pay.
Posted on Feb 29, 2008
I need to down load a sound driver and touch screen driver for my panasonic toughbook CF-73
The drivers of all Panasonic Toughbook models can be
found at the following website:
http://pc-dl.panasonic.co.jp/dl/search?q=&button=&dc%5B%5D=002001&p1=&p2=&oc=&lang=
Choose your model and operating system.
Good Luck
Mar 10, 2013 | Panasonic Computers & Internet
The laptop freeze and make noise
Two possible issues one bad hard drive or cooling fan. Odds are its the hard drive. go and download Hirens or DBan software so that you can test any hard drive. I insert the software boot it first then do a full inspection. If you get a error message that states like this, "No drives found in order to continue" odds are the drive is bad. Also usually if you boot it sounds like grinding or groaning noise it would be the hard drive. Especially if your shut down at the boot or it keeps recycling.
Nov 26, 2011 | Samsung RV511A01 Notebook
When playing a game or dvd, my Playstation makes a ticking sound like somethings jammed in it. It's possible my daughter stuck something in there and messed something up. It'll play and as time goes on the...
PS3 Clicking noise is associated with the hardware aspect, so that's your starting point it may come from the PS3 fan clicking, so do check out the fan if there's something that might have got stucked in between. Clogs from too much dust or dirt may also cause PS3 clicking sound.
PS3 clicking noise may also come from the hard drive. The hard drive are a bit noisy because of the mechanical parts and moving drive head when reading and storing data. Again, if the noise level is very minimal, there's no worry. PS clicking noise fro the hard drive that becomes too audible may signify that the hard drive is having mechanical problems and may soon broke down. At this point you may want to backup any data you have
I hope this helps you.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
My Panasonic Toughbook T2 was shut down properly and kept for about a month. now it does not boot. Even inital BIOS check function is not performed. Though HDD movement can be heard. Checked RAM by...
Is there any chance the video output is switched to feed the rear VGA connector? ie the screen is black due the video being routed away from the screen. Try hitting F5 key.
Can you hit the Delete key to try and enter the bIOS screen? (it may be another key such as F1 or F2. See your Toughbook manual)
Can you have someone make you a bootable USB thumb drive and try booting up with that?
Its also possible that the hard drive has failed, but usually the BIOS POST check will initiate and indicate a failed hard drive or bad RAM etc
Can you remove the 2.5 inch hard drive? Usually its accessible under a removable panel under the laptop.
Feel free to ask more questions.
Cheers,
Steve
PS have you tried the discussion forums on the Panasonic website?
May 03, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
When i use it it makes a wierd grinding sound
Take the computer to a qualified technician, for professional trouble-shooting (failing bearings in a cooling-fan, or a disk-drive about to die).
Apr 05, 2010 | Compaq Presario Notebook
Projector makes wierd noise and shuts down after several minutes
3 problems: 1- the light tunnel is collaping and needs replacing. 2- the tunnel might be hitting the colorwheel, which is now making that wierd noise. and 3- it needs cleaning. these models are famous for these 3 problems. there are no filters, so the dust just gets sucked in. the glue on the tunnel wears out from heat after a while. the colorwheel motor also wears out from heat and dust. the parts are not that expensive and they are relatively easy to install. contact an infocus authorized service center (from their website) and either get these parts or send it in.
tunnel- 306-0095-01
colorwheel- 525-0146-00
Aug 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have a Panasonic Toughbook CF-51. It fell off
i repair laptop every day and i have never seen and inverter board shut down the computer.in less it was total shorted. it sounds more like the fall my have damaged the hard drive. if a the drive wont spin it will cause the laptop to power down cause the little motor will over heat in a matter of seconds.if the laptop was on when it fell then its more than lickly the drive.
Feb 20, 2009 | Panasonic Computers & Internet
Installed new larger hard drive now crashing after an hour use
When you say "shuts down" do you get a BSOD (Blue Screen of Death) or does it just shut down without an error message? It definitely sounds like overheating. Try using a laptop cooler, something like this: http://www.overclockersclub.com/reviews/antec_notebook_cooler.php (I'm not saying you should buy that model necessarily, there are many such coolers). They can make a huge difference.
Apr 21, 2007 | Compaq Armada E500 Notebook
Panasonic Toughbook 50 Notebook Logo
113 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
