Question about Apple iPod MA446LL/A MP3 Player
Ipod will not turn on at all.
I was listening to my ipod and needed to be recharged so i plug it in to recharge it and when i unplugged it ,it showed a broken ipod symbol with a frown face and refered me to apple web site to reset but didn't fix the problem. Never had a problem with my ipod before now.
  • dj pro Mar 11, 2008
    My ipod was in my bag, I went to charge it and it won't do anything. It will not charge or turn on. It was working perfectly fine, then it just stopped.
    Problem Solver:
  • 25 Answers
Best bet is to get it into a repair shop. We can certainly take a look. It sounds like it could be hard drive issue or, best case, one of the ribbon cables came unseated and simply need to be reseated. I am concerned due to the fact that it shows that icon AFTER charging it. Was it hooked to an ac charger or computer?
Rick
EverGreenElectronics
Posted on Mar 09, 2008
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
Ipod won't power on.
Hello
Plug the iPod USB cable into the iPod and then connect it to the power adapter to recharge the iPod's battery. The iPod Shuffle may not be turning on because its battery has fully drained.
Move the button on the back of the iPod to the "off" position.
Wait five seconds with the iPod in "off" mode before switching the device back on. This process will reset the iPod memory.
Connect the iPod Shuffle to your PC computer if it still will not turn on.
Open the iTunes program and sync your iPod with your computer. When you unplug your iPod from your computer, it should turn on normally again.
Oct 23, 2010 | Apple Audio Players & Recorders
My ipod won't charge. keeps saying "please wait. very low battery" what's wrong with it?
I had the same problem. Went to the Apple store and the technician said that the IPOD battery ran down to low (battery level showed red) and the USB port on the computer was not strong enough to recharge it. He used a rechargeable adapter that pluged directly into the wall (adapter cost about $30) and recharged it enough for me to take it home and recharge it on my computer.He said to never let the battery level drop below 5% unless you are going to recharge it using the adapter that pluged into the wall. I bought an IPOD rechargeable travel kit from Target for $20 and used it to recharge my IPOD. My IPOD works fine now. The Technician also said at some point the battery will need to be replaced (in a year or two depends). Will cost about $59 to replace it (don't quote me on the timeframe or price of replacement, this may have been just for my IPOD but thought this would be useful info for someone.
Nov 24, 2009 | Apple iPod MA446LL/A MP3 Player
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
4th Generation ipod wont recharge
there must be a virus problem..a bbetter solution is put it on n let all the battery get over..and then recharge it from the beginning.
maybe ur connection is not proper. try putting the wire properly.
Feb 23, 2008 | Apple iPod nano
Ipod not turning on/not recharging
Have you tried holding down the menu button and the middle circle button?
first place your ipos somewhere flat and press down the circle button and the menu button,make sure your not touching any other part of the click wheel.hold them down for about 5 seconds untill the apple logo appears.then let go,and it should be back to normal.you can use this procedure any time that it freezes or stops working.Hope fully that should fix your problem.if not i suggest you get it repaired under your warrenty.
Good Luck.
Regards.
Sophie
Feb 13, 2008 | Apple iPod nano 3rd Generation
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Jan 12, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod recharging
how do i download Movies & photos to my apple ipod
Dec 26, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod always on hold
My 2 GB nano shows the lock icon no matter how many times I toggle the hold switch on and off and press the Menu/Select buttons. I've recharged and restored it any number of times with no luck. Computer recognizes it when I plug it in but once I unplug it, none of the buttons work. When it's plugged in and fully updated, it shows the languages menu. I'll be eternally grateful to anyone who can offer any assistance!
Dec 23, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
