Question about RCA 14F512T 14" TV
Blue Screen Popping Up Occasionally When Using Front Inputs
When I use my PS2 with the front/side inputs, and I'm watching a DVD, it'll occasionally go to a blue screen in the middle of the movie/episode but the .sound will remain
  • dterminal5 Mar 01, 2008
    well, thing is, my friend has the same problem with his RCA and we both live on campus and i dont think they'll let use solder stuff on campus plus, im not too comfortable cracking open my tv
    any other suggestions perhaps?
  • Anonymous May 07, 2008
    when i'm watching movies my screen will turn blank...well blue and I'm having a hard time finishing movies
Dterminal5-You could hooh up a vcr to your cable input and run your game or dvd trough it,or they also make a unit that will allow you to hook rca cables to your cable input( R.F connector). try this it is probably your only option without repair. cooltek Mar,4/08
Posted on Mar 04, 2008
  • 40 Answers
Dterminal5 - It sounds to me like the rca inputs are cracked on the pc board, I don't know if you are technical or not ,but it is an easy solder job to fix. Try this and let me know how you make out. cooltek Feb.29/08
Posted on Feb 29, 2008
Jvc projector blue screen
unplug it let it set hit power button plug back in might work for you
Aug 14, 2016 | JVC -HD DILA FRONT PROJECTOR THX CER -...
Connection using Component video No Video
1-Locate the audio/video input jacks AND the component input jacks on the TV.
Inputs are typically located on the back of the TV, but occasionally are on the sides, top, or bottom. They may also be located behind a hidden panel or door in the television.
Look for inputs marked Audio and Video IN.
Do NOT connect the system to anything marked OUT.
2-Connect the rectangular plug of the Component Video Cable into the Digital AV Out port on the back of the Wii console.
3-Connect the Component Video Cable to the television as follows. (Note that the Red and White audio cables are bound together with a black band labeled "audio.")
4-If you do not have a TV/Video button, then the input could be labeled something different. Some common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, AV, or a channel such as 00 or 99.
http://bit.ly/2ykOBno
Oct 13, 2017 | Aspire Digital AD-1000 DVD Player
Cant find input on screen to play dvd
Select av?, the ? is the number of the socket the dvd is plugged into, normally written next to the socket. If you are using the front/side inputs they will be a shared input so you may have to turn off another unit to view.
Sep 03, 2009 | Televison & Video
2 AV inputs, only 1 works at a time.
hello try using a scart block at the rear good luck
Jul 19, 2009 | Sanyo Televison & Video
Video input help
Hi....
Get a new A/ V cable for the PS2
Mar 22, 2009 | Sony PlayStation 2 (PS2) Console
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Aug 18, 2008 | iLO DVDR05 DVD Recorder
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
RCA 14F512T 14" TV Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
