Question about Kodak EasyShare Z740 Digital Camera
Won't turn on after changing batteries
My Kodak Z740 will not turn on after I changed the batteries. Before, it had a Duracell Ultra CR-V3. I replaced it with an Emerging Power CRV3 battery. But the camera will not turn on with the EP-CRV3.
  • tumblingon Apr 03, 2008
    I have exactly the same problem--I've tried several different batteries, and it just won't go.
  • 2,335 Answers
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Posted on May 01, 2010
My Kodak Z885 shuts off when I try to use the zoom even after I changed the battery to a DuraCell Ultra CR-V3. Any idea why?
I experienced the same thing while i was fixing a problem with my lens not extending fully. I simply used a vacuum cleaner over the lens to remove possible dirt/sand. After my initial (lens) problem was solved, using the zoom would automatically shut off the camera, so i used the vacuum some more and all the dirt preventing the zoom from extending is gone, so the camera works 100%
Aug 05, 2010 | Kodak EasyShare Z885 Digital Camera
Kodak easyshare Z740 battery problem
I hope that helps.
Oct 22, 2009 | Kodak EasyShare Z740 Digital Camera
Bought a kodak easy share z740 camera I love it very much but it just stopped working and I paid over 400.00 for it can I get it fixed or replaced
Won't turn on at all, or shuts off after a few seconds? This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. if charging/replacing the batteries doesn't clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jun 24, 2009 | Kodak EasyShare Z740 Digital Camera
Have Kodak easyshare Z740 camera, turn on and goes right back off. Battery seems to be fine tried several charged batteries. Mine does the same thing as well
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
May 31, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak Easyshare z710 will not operate
i switch the camera on the lens moves then it switches off
Jan 26, 2009 | Kodak EasyShare Z710 Digital Camera
Kodak Z740
I hope that helps.
Jan 03, 2009 | Kodak EasyShare Z740 Digital Camera
I hope that helps.
Nov 05, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak Z740, wont turn on!
plug it in dc power if you have a docking station the unplug the cord from the dock and into the camerea. regargable batteries only charge if the cameras sitting in a docking station
Oct 10, 2007 | Kodak EasyShare Z740 Digital Camera
Coolpix 2200/3200 Battery Compatibility
The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
Aug 30, 2005 | Nikon Coolpix 2200 Digital Camera
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
236 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
