Question about Canon Selphy CP510 Thermal Photo Printer
Canon Selphy 510
I have tried two new ink cartridges and the printer refuses to work. Error message shows cartridge are used up.
Any ideas?
Printer has hardly made 20 prints from new.
  • Anonymous Mar 23, 2014
    Selphy printer CP770. Computer and printer do not give any error sign, paper feed works but no actual printing takes place. Printer stays in the busy mode. If we remove the cartridge the foil shows a new colour after each try but the paper is still blank. The cartridge is brand new and original Canon.
    New Friend:
Where i can buy the wheel small gear?
Posted on Jul 27, 2017
    New Friend:
Hi! I have same problem. I opened cover (4 deep screws at the bottom) and found small plastic gear was separated from stepping motor shaft. I fixed it on shaft and my printer started work again. Today I will try to fix same problem on another CP510. I think same reason. Try to do it. Simple. vadim.y.astakhov@gmail.com
Posted on Oct 27, 2014
  • Vadim ASTAKHOV
    Vadim ASTAKHOV Oct 30, 2014
    Today I found my printer out of order again. I disassembled my second printer. With the same ink error. The small gear was on shaft, but slided to the end of shaft. Anyway I tried to mix both printers on my three PCs and two cameras. I concluded the reason of ink error is bad driver..No good for every PC. With my old notebook with WinXP both printers work ...
I have a similar problem saying that the cartridge was not installed. Try winding the film on until you can just see the yellow film and try printing again. This normally fixes my problem for that print run, but the problem seems to regularly re-occur. Hope this helps.
Posted on Mar 04, 2008
  • Douglas
    Douglas Feb 22, 2018
    I am having the same problem with my selphy cp-720. When trying to print, the paper goes through the printer; then on the return stage it stops and there is a crunching sound, and the small gear wheel slips off its spindle. It seems to be a mechanical failure.
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
Hi there, Canon Selphy CP-720 from a Mac via Time Capsule... Printer tells me on its lcd screen that the ink cartridge is out, I've bought a new one and same message!! Any ideas? thanks
Welcome to Fixya. Can you provide the exact error that you have on the LCD so that i can provide you the steps on how to fix the issue
Thanks
Jul 12, 2011 | Canon SELPHY CP720 Printer
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
I have a Selphy 710 that I've seldom used. Now when I insert a new ink cartridge, it cycles to the end and error box says "Ink cassette is empty and must be replaced." I've replaced the...
I'm having the same exact problem with my CP730. The paper size and ink cartridge are the same size. I've tried two new ink cartridges, same result. Frustrating and expensive.
Mar 09, 2011 | Canon SELPHY CP710 Thermal Photo Printer
Unable to resolve 'cartridge has been changed' error message
turns out the wrong paper size was selected in the print setup. I set it to Postcard (4x6) and it began working perfectly again. Hooray.
Jun 01, 2009 | Canon SELPHY ES30 Thermal Photo Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Selphy CP510 Thermal Photo Printer Logo
1,065 people viewed this question
old marine
old marine
