Question about KitchenAid KEHC379 Electric Double Oven
Stain inside double glass microwave door
How does one get the microwave door apart to clean stains on the inside of the double glass door?
    Genius:
  • 1,554 Answers
Most microwaves have screws on the top and bottom outer lip edges. or under the rubber grommet if it has this .
but this unit should have a 10 year warranty and they may cover this issue call them
http://products.construction.com/portal/server.pt/gateway/PTARGS_0_2_493_204_249_43/http%3B/205.142.52.224/swts_content_files/15315/211253.pdf
Posted on Feb 29, 2008
Hi I have a Daniela Oven - Model DAN6FCS. I have stains in-between the 2 layers of glass in the oven door. What is the best way to remove the inner glass to clean?
The best thing to do is leave it alone. The double glass is a "sealed" unit not intended for maintenance. Even if you were able to take it apart, you would then have a porous seal that would get stained even sooner.
Aug 12, 2018 | Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
How do you clean behind glass on oven door.
you will have to remove the door from the hinge mounts. then the door has screws at the top and bottom, as well as some have screws going into the handle.
lay the door on a big flat surface, remove the screws, then seperate the front from the inside. that should give you enough access to get to the stains on the glass.
Jan 09, 2010 | Ovens
See through oven glass window stained
this is common its called vapor lock look for screws holding in the glass if none are found there is a rope looking seal around it take a hook or pliers and remove it the glass will come out you can clean in between it and put it back fairly easily.
Dec 30, 2008 | Ovens
Self-cleaning heat stains on the front facing panel
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning in between oven door glass
first its a whole lot of effort for very little return second there are two 100 pieces of glass in there and three it will just do it again but if you still want to reply with the brand and model number ill give you the procedure most of the time its backed on and leaves a stain even after cleaning
Jan 19, 2008 | KitchenAid Architect Series KEBC107KSS...
KitchenAid KEHC379 Electric Double Oven Logo
454 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
