Question about Brother MFC 7420 All-In-One Laser Printer
Printer error assistance please.
My Brother MFC7420 is displaying a 'fuser error' message. What does that mean is wrong and needs fixing?
  • mammakez Mar 09, 2008
    Hi, your link to Brother was most helpful - I couldn't find anything remotely helpful on their site and gave up trying because I couldn't even find a mention of a fuser. They have now sent me an service address in Coburg which is nearby. MK>
  • 26 Answers
Sorry mammakez, sounds like the fuser needs replacing (they arnt servicable), its a replaceble part but going throught the motions to get brother to send you a new one is like pulling teeth. i suggest you go here for a start
http://www.brother.com.au/customersupport/productSupport.asp
good luck
Posted on Feb 29, 2008
My HP LaserJet printer 5200dtn is displaying error message "50.3 Fuser error" what is the solution to this problem because I can't print
50.3 means the fuser is getting too hot. It will either be a problem with the thermistor in the fuser or the power supply. If you can find a another fuser to test with you can answer the question pretty quickly.
Mar 02, 2015 | HP LaserJet 5200dtn Printer
Machine error 28
Well it's a low temp error for the fusing assembly. Sounds like you already had it in Maintenance Mode. Sometimes those errors can only be cleared out by entering maintenance mode and pressing 9,9 to exit out. Should then start the normal warm up procedure. If the problem continues then reseat the fuser or take it out and measure for continuity across the lamp and thermostat. The service manual also recommends checking the line voltage. Basically make sure it's plugged straight into a wall outlet and no other large power sources on the same circuit. Example, another copier or this time of the year a small space heater.
Maintenance Mode enterance Press Menu/Set and Black start button and Up arrow 4 times. Machine will read Maintenance on the display if done correctly. Press 9,9 to exit of the mode and the machine will attempt to restart normally.
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Feb 11, 2014 | Brother MFC-9420CN All-In-One Laser...
HOW CAN I CLEAR ERROR CODE 70 .Brother DCP -195C
Brother Printer is one of the best printing machine and comes with bundles of excellent features. Brother Printing machine is known for its high quality printing feature and its customer value. But sometimes user encounter various kind of problem while working with printing machine like Driver installtion and upgrade issue, Printer Set up/Configure issue, Paper Jam issue, Spooler error, Machine unable to print , Error code and so on. And being as a novice user you don't know how to fix them all issue then its recommended to get in touch with Brother Printer Support Experts for on the time assistance.
Here in this post we have mentioned about Brother unable to print 70 error message and how to fix it.
Require Sequential Steps to Fix Brother Printer Error Code 70
1. First you need to turn off the machine for few minutes then turn it ON again. If problem not gone due to turn ON/OFF process then you have to open the back cover.
2. Now carefully pull the green tab at the left and the right sides then fold down the fuser.
3. Always remember one thing there is no paper stuck inside the roller.
Note: If user doesn't find any kind of paper inside the roller then close the cover carefully. But if paper stuck inside the roller then gently remove it or close the cover.
4. Finally Turn ON the printing Device, if it shows ready it means unable to print 70 error has been fixed.
Above listed steps definitely resolve your printer error. If stil you are troubling with same error then its recommended to get in touch with Brother printer support experts at yahooemailsupport or pick a phone and make a call on toll-free Brother Printer Support Number 1-833-327-1999.
Brother Printer Customer Support Toll Free Number USA
Mar 29, 2013 | Brother DCP-195C A4 Colour Inkjet...
Reset fuser life counter MFC 8660DN
Thank you for the inquiry.
This is a common occurrence after fuser replacement and no information is in the manual.
1) Press the 3 and 9 buttons at the same time in the ready status.
2) "Reset Menu" will appear on the LCD. Scroll to Fuser by pressing up arrow or down arrow button then press the OK button.
3) "1. Reset 2. Exit" appears on the LCD. Press the 1 button to reset the fuser counter. The display briefly shows "Accepted".
The machine returns to the ready status after a few seconds.
I hope We've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response.
I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Best regards,
TF
Jun 03, 2011 | Brother MFC-8660DN All-In-One Laser...
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
Brother DCP1200 Machine Error 76
This refers to a error with the fuser temperature you need it repaired by a service technician. Parts can be as little as $15 for the thermistor sensor or as much as $100 for a new fuser.
Jan 04, 2010 | Brother DCP-1200 Laser Printer
Error message 0500h
Your fuser is not warming up. You will need a technician to look at it.
Mar 16, 2009 | Konica Minolta magicolor 5430 DL Laser...
What is media jam fuser error
It means there is a paper jam in the fuser (the hot part that fixes the toner to the paper).
Check if there is any sheet jammed inside your printer or if any sensor is in the wrong position.
If everything seems to be ok, you may need to replace the fuser.
Nov 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Brother MFC 3100 Printer/fax
This is the only reference I could find on error 41: How can I clear the message Machine Error 41 from the display? (ME41)
Machine Error 41 indicates a mechanical malfunction of the Brother
machine. Unplug the unit from the power source and then plug it back
in.
If the error message continues to be displayed on the LCD, please call
Brother Customer Service at 1-800-284-4329 for assistance. The Customer
Service center is open Monday through Friday, from 9:00AM to 7:00PM,
excluding holidays If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 16, 2008 | Office Equipment & Supplies
Brother MFC 7420 All-In-One Laser Printer Logo
142 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
