Question about Brother MFC-3240C All-In-One InkJet Printer
Mfc 3249c will not print magenta! Screen indicates that magenta is low but it is not, It is full and has had many cleaning cycles but still no magenta.
  • pfdtx Jul 13, 2008
    My MFC-3240C keeps saying the Magenta is near empty. I've put in two new cartridges and still have the same error.
    Problem Solver:
  • 12 Answers
Ensure that you are replacing the cartridge with a Brother LC41M ("M" denotes magenta) cartridge instead of replacing it with a "knockoff" (third-party equivalent) or refilling the cartridge. Some third-party inks -- found in many knockoffs and ink refill kits -- do not work well with their intended cartridges and/or print heads. I discovered this the hard way, and then verified it with representatives of HP, Canon and EPSON.
If you have tried two or more actual LC41M cartridges and still receive the Near Empty error message, your unit might need service. Contact Brother Customer Service for further troubleshooting -- see page i of the Users Manual. (Opening the Users Manual with this link requires a PDF viewer such as Acrobat Reader or Foxit Reader.)
Posted on Jul 21, 2008
Magenta won't print at all on test page. Tried normal cleaning cycle several times to no avail. Also tried "power purge" cleaning cycle twice also with no success. Help!
The magenta print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 20, 2013 | Brother MFC 6490CW InkJet Printer
My brother mfc j220 canoot print magenta color although on the display the magenta is full i clean many times but when i test print i didnt see dotted magenta. what can i do?
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 06, 2011 | Brother MFC 210C All-In-One InkJet Printer
My MFC 490 cw only prints yellow and magenta. All
You should run a few cleanings. Push the ink button then down arrow for cleaning and push ok.
Mar 27, 2010 | Brother MFC 490cw Color Inkjet...
MFC 210c problem with Magenta ink
I had a similar problem with my black ink. The printer had indicated that it was out of black ink. I didn't have one on hand, so, for more than a week I couldn't print anything, because if you are out of any one of the four ink cartridges, it won't print at all. That delay in replacing the black ink cartridge apparently was enough time for the printhead to dry out. Big Mistake! I contacted Brother's Tech Support and they suggested I run the cleaning cycle and try to print a test page. Still nothing printed. They had me run another cleaning cycle, and another, and another. Finally, after the fourth cleaning cycle, something started to show up on the paper. They had me clean it two more times, six in all, and it was back to normal. From now on, if it says one of the ink cartridges is empty, I change it yesterday. The major disadvantage of all of this, other than not being able to print for awhile, is that this procedure used up about 1/2 of a brand new black ink cartridge.
Oct 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
Red Menace
Try unplugging the printer for about ten to fifteen seconds; then replug.
This may clear the printer's memory about the low magenta. I had a similar thing with yellow, and when I replugged it stopped complaining about the yellow and told me that my cyan was out, and magenta low. I replaced the cyan, and voila! I can print!
Sep 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Will Not print magenta
hmmm...even on a test print page?
Feb 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
Printer won't print magenta
So what does the machine do: Not recognizing the cart (error: insert magenta) or does it not print onto the paper?
In 1# case: Reinsert the magenta cart and make sure that the support is secured above the cart top. If it is recognized: OK.
If not unplug mfc from power. take all carts out. Wait five minutes. Reconnect machine to power. wait until machine demands carts. reinsert cart as demanded and give the right answers (see display).
Machine should run a short cleaning cycle.
In 2# case: Insert full carts well. press menu then start mono (blue) then fourtimes arrow-up (te-index). machine will be in maintenance mode. press 7 then 6 then 4. machine will initialize the carts. after some cleaning cycles machine will be
in mentaenance mode again. Press 9 then 9 to leave mode. press ink etc. to run a test print. If it fails and you cant see any magenta, the valve or filter is clogged and cant be fixed anymore.
Nov 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Printer will not print black.
Try removing the magenta completely and shut the lid then open again then insert the new magenta and see if the ink device level on the PC shows full. Sounds like the system needs resetting. Alternatively change the magenta and power on and off the printer and see if this resets it.
Aug 29, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
160 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
