When I try to backup to the D:/ drive, my computer says that it does not exist
  • Anonymous Jun 05, 2008
    When I try to back-up my hard drive, it asks me to put a disk into drive F. I don't have drive F. I only have drive D for CD's.
    Genius:
  • 3,587 Answers
Gotta love that D drive..
go to my computer, and see if it's listed on that panel
Posted on Feb 29, 2008
Samsung recovery solution 5
Step 1:
Step 2:
Once Samsung Recovery Solution 5 loads, click Restore.This display is observed.
Step 3:
On the Restore > Complete Restore dialog, there is list of backups created using Complete Backup and the expected time needed to perform a restore with each backup. If no backups have been created then the Computer Initial Status backup is the only item listed. Click the backup you would like to use for this restore, and then click Next.
Important: Make sure you have power connected to the PC. If power is lost during a restore, you need to start the process again from the beginning.
Step 4:
Samsung Recovery Solution 5 prompts you to restart the computer to continue. Click OK to restart the computer.
Warning: If you have data on drive C that you do not want to lose, stop now and perform a Data Backup.
Step 5:
The computer restarts and Samsung Recovery Solution 5 prompts you to click Yes to Delete all data on drive C. Click yes to proceed.
Step 6:
A progress bar appears showing the current transfer speed, the amount of data copied, elapsed time and estimated total time to completion.
Step 7:
After the Complete Restore is complete, Samsung Recovery Solution 5 prompts you to restart your computer. Click OK to restart
Step 8:
After you restart your computer, the restore process is complete.
Note: You will need to perform an additional restart for Windows to apply its changes.
Mar 18, 2013 | Samsung Cell Phones
Computer dosen't turn on. i ran the hard disk test it says "hard disk not exist"
There could be two possible problems here: A bad cable or a bad hard drive.
If you have a desktop computer, you could try swapping the cables over from your CD drive with your hard drive.
Failing that you need to get a replacement hard drive.
If you have a desktop computer, you need to check the connections on the existing drive or motherboard to see if you have a ribbon cable that connects to the drive and the drive has lots of pins to connect it, (IDE or PATA) or a narrow red or yellow (SATA) cable. You will need to get a 3.5" hard drive.
If you have a laptop computer, you also need to check the connections on the existing drive, if it has pins (IDE or PATA) 2.5" drive or if it has L shaped connections (SATA)
You will also need to reinstall the operating system from its installation CDs or backup disks. If you don't have them, you will need to obtain them from your manufacturer.
Jul 22, 2011 | Computers & Internet
When i try to transffer data to the sandisk sd 2gb card im getting 0x8007045d error help please
it is because your card is formated as FAT ( this means that you can only store small files on it ). To fix this do the following 1. open my computer 2. right click on th sd card 3. press format 4. in format select fat32 instead of fat 5. click format (you will lose all data currently on the card) 6. when it is finished you should be able to copy files onto it
Mar 16, 2011 | SanDisk 2GB microSD Memory Card
I want to back up a 2nd copy of a quickbooks pro 2006 file but it won't work. When i try and load it from the backup file on my hard drive it says that windows cannot open the file, and to use a program...
You need to make the backup from quickbooks using file,
backup. Select the drive you want the data stored on. Then if you need the backup data you need to use file, restore.
you are only backing up the data so you have to run the
file from the program, with the restored data.
Sep 19, 2017 | Intuit QuickBooks® Pro 2006 Full Version...
I am trying to extract my backed up files from my Seagate FreeAgent go....but not sure how to..I don't see a restore option under backup on the Seagate Manager as the instructions say.
The only time I have seen this error, no backup was ever performed (or the program lost the information regarding existing backups). Try looking at the backup log (Seagate Manager > View Backup Log) to see what backups should exist.
I hope this gives you a starting place and wish that I could be more help.
Mar 28, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computer says destination is full but the flashdrive is empty. 7.46gb free. transfer of 4-6.5gb files
may be the pen drive is infected with virus Just backup the existing file of flash drive to another drive and format the flash drive and try to copy the files.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How do i format my computer without losing the drivers?
Try this type of application to backup all the drivers in your existing Windows to a USB drive. (Portable version is best for this type of operations)
Portable Driver Genius
Beware that drivers backed up may have a missing character in the front of the folder name.
The best way is download the latest drivers version from your PC vendor or the motherboard's manufacturer before formatting your XP.
Apr 17, 2009 | Microsoft Windows XP Professional With...
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
Apr 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I am receiving the following message when I attempt to access my Western Digital My Book 500 GB: "Ox8007045D I/O Device error" I can see that my photos are still there but cannot open them or copy into the...
Happened to me too in both file backup and computer backup. I supposed MS will address in the future. For now, go to the system settings and unchecked the drives so they no longer create shadow copies . Apply the new settings to erase all existing shadow copies. Then reset by checking the boxes you unchecked. Now try to backup the whole computer again. It appears a shadow copy error is conflicting with the backup process. Once you delete all shadow copies (restore points) it will work.
Jan 05, 2009 | Western Digital My Book Essential Edition...
Quickbooks pro2008- can't seem to update data from a backup
You will need to say "yes". This will install all the data from your business computer so your laptop computer data matches your laptop. The only problem comes if you have made changes on your laptop that you didn't bring over to your business computer. If that is the case, those changes will be lost when you update.
Jan 03, 2009 | Intuit QuickBooks Pro 2008: Windows
Computers & Internet Logo
23 people viewed this question
Alun Cox
David Payne
David Payne
