Question about GE WWSE5200B Top Load Washer
Ge washer model wwse5200bww top load
When you turn the dial the lights come on, but it will not start even when you press the start button. for quite some time it would almost always stop somewhere in the middle of a cycle normally after filling for a rinse.
any ideas?
  • 156 Answers
Possible bad control board
Posted on Mar 03, 2008
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Washer stops by itself, have to press start continuously
I would check the inverter on top of the motor. The flashin led light is a code the code legend is on the wiring schematics behind the control panel
May 07, 2010 | GE WBSE3120B Top Load Washer
Won't turn on - press the start button and nothing. hold it down and it will light up, however water will not start nor does the cycle start. Unplugged it and replugged back in, tripped the circuit and...
Husband came home from work - looked at what was happening. It appears service is needed due to circuit board issue; technician will be at house this am.
Sep 16, 2009 | GE Profile WPRE6100G Top Load Washer
Waher fills and then quits, won't start the wash cycle
LAT7300AAW that is your model number AZ103872 FD that is your serial number
Jan 02, 2009 | Washing Machines
Will not wash!!
Dangercart82,
I would recommend starting off by trying a different cycle. Change the dial to the spin cylce, or a different type (perm press, normal, knits) and see if it has the same problem.
-Davedwin
May 09, 2008 | GE WBSR3140DW Top Load Washer
GE Model 7-4837B
press the Cancel button located on the top of the alarm clock (the light next to the wake mode indicator on the front of the clock should start flashing). Then press the WAKE Mode button on the top of the device. The wake mode indicator on the front should now be off and the alarm deactivated.
To turn the alarm back on, simply press the WAKE Mode button on the top of the device.
Mar 27, 2008 | GE 74801 Clock Radio
GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Dec 18, 2007 | GE WBSR3140DW Top Load Washer
GE WWSE5200BWW Topload Problem
sounds like the motor needs replaced pretty common on this unit..
May 28, 2007 | GE WWSE5200B Top Load Washer
GE WWSE5200B Top Load Washer Logo
166 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
