Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet's interupted cycle won't restart
The cycle must have been interupted (possibly by my 2 year old).  There is water in the tub and the timer light is flashing.  I cannot, however, get the machine to resume the cycle.  What should I do?
    President:
  • Whirlpool Master
  • 2,651 Answers
Unplug, let sit for 2 min, replug and try to put into drain/spin cycle
Posted on Feb 29, 2008
I want to open the door mid cycle and restart it. Instead when I push pause the door remains locked and I can't insert another item without draining the water and starting over.
Yes that is how that style washer works since its very possible if opening the door when water is in the tub that it would spill out when opening the door when water in the tub..all front loaders work ina similar manner where when water is in the tub the door wont unlock
Aug 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have the WFW9150WW00 duet and the front load washer wash light blinks and it will not wash. What to do? My wash room only has a cold hook up. Does this type machine have to have a hot connection?
I have the WFW9150WW00 whirlpool duet, I start the cycle and it starts to wash and then starts beeping, I push the start button and sometimes it will finish the cycle fine and other times it will just shut off like it is done and clothes are dripping and has never finished the other cycles. What is wrong
Feb 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
Feb 11, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gentle cycle did not complete leaving water standing in the tub.
Whirlpool downloader washer model number GHW9150PWO
PROBLEM Gentle cycle did not complete leaving water standing in the tub
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet won't spin clothes at high speed
Thinking of 2 things either the transmission is out or the clutch is burnt out and the drum basket and possibly the drive shaft broken as well. Prices vary greatly by how many of these things are broken but should run between 100-200 including labor.
Dec 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F28 error - does not drain
She is no longer having the problem - turned it on and it went through all the cycles - possibly a reset.
Thank you
Nov 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
358 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
