Apex Digital GB4308 43 in. Rear Projection EDTV-Ready Television
Problem for Apex Digital GB4308 43 in. Rear Projection EDTV-Ready...
Convergence IC's replaced, still won't converge
By frankgant on Feb 29, 2008
Okay, so I had the normal problem where my convergence was off and I couldn't adjust all of the lines but I could save what I had done. So I replaced the IC's. However this hasn't fixed my problem. I still can't move the lifes sideways when in red but can move the up and down lines. What in the world is going on? Is it possible to have another bad IC even though it was brand new? And is there a way to tell which one on the board is controlling the red lines? Could it be something other than the IC's?
your help is appreciated.
Comments:
Mar 02, 2008
- I have now tested the resistors and found one to be out of range. Should be 2.2 ohms and it's reading .796. So well out of range for it. Bet that's my problem. Now I just need to find these darn resistors.
Mar 29, 2008
- Okay, I had it all working. Moved it into the house from the garage where I was working on it and now I can no longer adjust the convergence at all. What the heck is going on. lol
Solution #1
posted on Apr 29, 2008
Not Rated)
daml
Rank: Master
Rating: 85%, 7 votes
I had a similar problem. Purchased a rptv second hand. Got it home convergence was off (was OK prior to moving it). Turns out it was a dry solder joint. Check underneath the conv pcb.
Was this helpful?
Yes
No
Popular Solutions for Apex Digital GB4308 43 in.
Questions and Unsolved Problems for Apex Digital GB4308 43 in.
Do you recommend Apex Digital GB4308 43 in. Rear Projection EDTV-Ready Television?
Answer
Answer
TV won't turn on, the light comes on and turns red like it will kick on, then flashes back to... (More)
Answer
my samsung tantus tvs color is all messed up..their are colored lines and the picture is jumping up... (More)
Answer
double vision and tv doesn't have a auto convergance. I can't get it to work manualy.
Answer
Apex GB43HD10 wont turn on you can hear a low tic sound from the power supply pcb.. no led lid on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apex Digital GB4308 43 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
