Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Magic usb hard drive
Will not come up on pc
  • 1,006 Answers
Just buy new external ( hdd is fine ) then pun that hdd in new external and everything will work fine
Posted on Feb 29, 2008
Need driver I/O magic 8gb external hard drive
Is this large drive compatible with your PC, check that out. Contact the manufacturer's support site for this information and any needed software.
Oct 01, 2016 | Magic Computers & Internet
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
How can I get this device to read on an xbox 360?
Step 1: Connect your hard drive to your PC.
Step 2: Create a FAT32 partition on your hard drive. If you’re using less than 32 GB, you can use Windows via “Control panel > Administrative tools > Computer Management”. If you’re using more than 32 GB, you’ll have to use an external program, e.g. Partition Magic.
Step 3: Load all the content you want from your PC onto the external drive. This should consist of files that can be read on the Xbox hard drive.
Step 4: Remove the external hard drive from your PC. Plug it into your Xbox 360 console through the USB port.
Step 5: Go to the Media menu on your Xbox screen. Select "Portable Device" from the menu. All the readable files saved on the external drive should be available to read on your Xbox 360.
N.B. Xbox's connection with an external drive is read-only. You can only read files that are already on the drive after connecting. You can't save game files or anything else on the Xbox main drive onto the external hard drive. Also, USB storage devices cannot be used for Xbox live marketplace content.
Apr 12, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Will power up but won't show up on computer
I would try a different USB port on the PC and a spare cable if available.
Jan 20, 2010 | IO Magic Corporation GigaBank (I250HD35)...
I plug in my external hard drive and my pc will not read it. It shows up in the usb remove saftly as mass storage. I can not get to my data??
is the external HD formated ?
open My Computer and press F5 or click Refresh from the View option in menu...
check if u get a new drive letter....once u refresh...
Dec 14, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Pc hard drive
Yes, that correct you can just need to take the hard drive from your desktop and get a external hard drive ecnlosure where you need to put the hard drive and connect it to your laptop via USB cable, check this link for the sampole of the hard drive enclosure that you need to buy http://www.tigerdirect.com/applications/Category/category_tlc.asp?CatId=2777&name=Hard-Drive-Enclosure
Hope that helps.........
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
IO Magic Drive power replacement
All you need to do is ask at a computer parts store for an external hard drive enclosure.Take the hard drive with you and they will be able to give you the correct size, there are 3 sizes available, 1.8" (has a drive the same as an ipod in it), 2.5"(has a laptop /notebook hard drive in it), and a 3.5"(has a full size desktop hard drive in it).
The other option is you could just completely remove the drive from the io magic case and install it into your computer as an extra drive.
Jul 02, 2008 | IO Magic Corporation GigaBank (I250HD35)...
I/O Magic external drive not showing up in computer
Extreme temperatures, either very hot or very cold, can certainly cause damage to your External Hard Drive.  Based upon your description, it sounds like the hard drive enclosure has been damaged.  This would explain why device manager can not recognize it.  Your hard drive is plug-and-play with Windows XP, so no drivers are necessary.  Have you tried plugging it into another computer?
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available on the I/O Magic website.  Make sure to get the right size enclosure.  Your hard drive has a 3.5" hard drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still isn't recognized by multiple computers, then the hard drive inside the casing has probably been damaged, and I would recommend contacting a data recovery specialist.
Have a nice day,
I/O Magic Technical Support
Mar 10, 2008 | IO Magic Corporation GigaBank (I250HD35)...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
73 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Falling star
nuhu ibrahim
nuhu ibrahim
Level 1 Expert
John Lavis
John Lavis
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
