Question about LG 47LC7DF 47 in. LCD HDTV
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
Picture quality of LG 47'' HDTV 120H is AMAZING but the left and right edges are cut off. Ex.: on ESPN, they usually have 'ESPN' in the bottom left corner...All I can see is 'ES'
..Any Ideas? We have tried changing the Aspect Ratio and have found a way to 'Zoom' but that only changes the top and bottom, not the right and left sides...
Thanks!
  • The TechGuys May 11, 2010
    are you using a cable box or satellite? both have features in them to control this..let me know
    New Friend:
  • 7 Answers
Hi, Dude.
You have to try http://www.wikiebooks.in For the Perfect LG LCD you probebly find it.
Posted on Jun 01, 2012
  • 4,889 Answers
Yes I can confirm that this is an aspect ratio problem. On this particular set you have to press the menu button-Select the Picture sub menu and change the aspect ration to 4:3 as 16:9 is usually recommended for sets with screens larger than 50". I personally own a 42" set and 4:3 works just fine for me where as 16:9 will cut off the edges.
Posted on Oct 09, 2011
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Posted on Jan 21, 2011
SOURCE:
Adjust my 40 Samsung 1080p 120Hz LCD to see the entire picture. t is currently cutting off the edges; left, right, top and bottom
First check if your zoom is on..if it is switch back to normal setting. If picture is still cropped with no zoom then try go to the menu seen string and check for aspec ratio..try different sttings..
Feb 23, 2015 | Samsung UN40EH6000 40-Inch 1080p 120 Hz...
LG tv model 47LK520 has audio but no picture screen is grey. what is the problem?
Most likely your input button needs to be on a different input , if you have cable on HDMI #1 and a dvd player on HDMI#2 make shure your input button on your remote is on the right input ...also double check your HDMI cables that they are working because I have had cases where they go bad ! hope this helps Sincerely Glenn
Sep 02, 2014 | LG 47LK520 47 inch LCD HDTV 1080p 120Hz
My picture all of a sudden gets darker. How do I fix it
read the book! sum 1 else is suffering the same problem, google this and look for a you tube video. lol.
Jul 22, 2014 | LG 47lw5300 47-inch 1080p 120hz Cinema 3d...
Turns on, shows picture, but whiteish grey with vertiklcal lines
Sounds like main digital board fault. Contact the authorized service center for LG.
Gopakumar Gopalan Google
Feb 13, 2014 | LG 47LM4600 47 Inch Cinema 3D 1080p 120Hz...
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
Why do bright colors bounce on my lg tv?
I had this issue on a 40" Seiki TV. I turned off the 120hz setting and also the Noise Reduction settings in the Menu and it stopped.
Jan 12, 2013 | LG 47lw5300 47-inch 1080p 120hz Cinema 3d...
No backlight no sound no picture lg 47le5400
it needs proper trouble shooting, just let me know if you will be the one to do the job.so i can give you other step to trouble shot the tv since it needs proper tools and device then make sure you have the knowledge in electronic repair.
Oct 25, 2012 | LG 47LE5400 47-Inch 1080p 120Hz LED LCD...
I want the best picture from my 50" LG plasma tv, and I just replaced my 47" LCD LG tv with this plasma and I am not impressed at all compared to my LCD. I guess my question is what a are the best picture...
to C_LATKA:
Hi, I recently bought a 47" LCD LG the latest model and I read that you had purchased it previously and I wanted to know how you found the quality of picture on the LCD? At the moment ours is a bit blurry. I hope it was worth buying. Do you think we just need to tune the picture quality?
Jan 07, 2010 | LG 50PX5D 50 in. Plasma HDTV
LG 47LC7DF 47 in. LCD HDTV Logo
598 people viewed this question
RONALD CARTER JR
