Question about Dishwashers
Dishwasher machine does a full cycle but the dishes are not completely clean. There does not seem to be a blockage. Have used some CLR but to no avail. Thanks for your help. Isobel Jones
    Sergeant:
  • 351 Answers
Check loading, water level,soap use(too much soap)and rinse aid.sorry i cant give more help but dont know what brand,model etc.
Posted on Mar 02, 2008
Clogged Bosch SHU 9920 dishwasher
-Sounds like the pump is not working properly or the drain line you connect to sink directly instead to the breath cap before to the sink. Or the breath cap locate too low.
-Make sure the breath cap is mount higher than the line to the sink. (Or as high as possible) This is to prevent any water from the sink pour into the dishwasher.
Good luck
Mai
Jun 16, 2017 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Tip
We had an ongoing battle with white film on glasses and dishes, inside...
<p>If your <b>dishwasher does not seem to be cleaning well</b> anymore and you are getting<b> residue and film left on your dishes</b> then you need to read this.<br /> <p><br /> <br /> <p>Since July of 2010 the US Government has mandated that <b>dishwasher detergents</b> contain no more then 0.05% phosphates in them. The Detergents before this had contained up to 8.7% phosphates. The restrictions were for 16 states but many companies then dropped the phosphates from detergents to all states...<br /> <p><br /> <br /> <p>Now if you are having the <b>scum, film, and white residue problems</b> in your <b>dishwasher, </b>there is hope.<br /> <p><span>There is a product that you can buy that will compensate for what the makers of the </span><b>dishwasher detergents</b><span> have left out. This product as commonly know as </span><b>TSP</b><span> or </span>(<b>Trisodium Phosphate</b>).<br /> <p>By adding this to your dishwasher, you can manually add back the phosphates to your dishwasher and enhance the cleaning process.<br /> <p><br /> <br /> <p>Now the nest question...how much TSP do I add to the dishwasher?<br /> <p><br /> <br /> <p>For many dishwashers, waters, and for normal loads you will find that a tablespoon or two is all that you will need. For very hard to clean dishes and for some types of water you may need to add up to a 1/3 cup of TSP. <br /> <p><br /> <br /> <p>If you are having problems with your <b>dishes not getting clean</b>, a <b>black or scum film</b>, or <b>white residue</b> being left on your dishes at the end of the cycle, then I would start with a tablespoon or two and then adjust from there. Figure out how much you need to add to you dishwasher to make your <b>dishwasher detergent </b>work correctly for you again.<br /> <p><br /> <br /> <p>To best part is that you can have <b>clean dishes </b>coming from your dishwasher again!!<br /> <p><br /> <br />
on Mar 31, 2011 | Dishwashers
Dishes not getting clean. Long cycles.
half a jug of CLR in the bottom of the machine on a full wash cylce will do wonders. Set it to the longest and hotest setting. let it run until the bottom fills and let it set for about 30 mins to an hour....The longer the better you chances of getting it right on the first try. Keep stopping your machine for each fill and let it cycle through.
run atleast one more cycle before you put dishes in their.
HOT WATER CARRIES MORE MINERALS THAN COLD WATER!!!!!!!!
Naturally, hot water dissolves more minerals than cold water. This allows for a larger change of mineral build up at junctions, especially those exposed to air. Try a toothpick in the holes on the sprayer, just be careful not to push it all back in and create a blockage
GOOD LUCK AND PLS RATE THIS POST!!!!!
Dec 01, 2010 | KitchenAid 24 in. KUDI02CRBS stainless...
I have used dishwasher cleaners, use Cascade Complete dishwahing detergent but all of the sudden, my dishes come out of the dishwasher dirtier then they went in. The glass glasses have a gritty stuff...
depending were you live they changed the formula in cascade,but they are doin a new formula are you using a rinse agent? claean the machine clean spray arms and soap dispencer,with no dishes run machine with 1cup of CLR or 2Cup of vinegar just pour in tub and let it run full cycle no drying.Thanks
Jul 31, 2010 | Whirlpool Dishwashers
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
May 16, 2010 | Dishwashers
How do I clean off calcium deposit from dishwasher coils? I have calcium build-up on the bottum coils of my dishwasher and my dishes come out filmy.
I suggest you descale your machine with a cleaner such as C.L.R. Any cleaner with Phosphoric Acid will do a good job. The best way to clean your dishwasher is to pour a litre of this cleaner into your machine, and run a complete cycle. (without dishes in the machine) You may need to repeat this process every month depending on the hardness of your water.
Regards
Jan 18, 2010 | Frigidaire Dishwashers
No water flowing through jets
CLR can be great if it is hard water blockage. If it is food blockage or a lot of hardwater you will have to dissassemble part of the sump pit and manually clean the blockage. Please rate this post.
Dec 14, 2009 | Washing Machines
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Water seems to be hot enough, drains properly, arnms not blocked, dishes not being cleaned at end of cycle. Almost seems like it is skipping the wash cycle.
Hi smiller8565,
There is 3 basic problems that will cause a dishwasher to not clean the dishes. You can check these problems and see if any will solve your problems.
1: If there is water or suds left in the dishwasher after the cycle is complete. This will cause dirty water to be used in the final rinse and the dishes will not get clean.
2: The pump that supplies water to the spray arms is jammed or defective and unable to pump the water properly, thus causing the dishes to remain dirty.
3: Timer, the timer is not allowing the machine to work in the wash cycle.
The solutions for these 3 are as follows.
1: check the drain line for blockage, if you have a disposal make sure it is clear and water flows down the drain properly. If you have suds left in the dishwasher, clean them out and run a couple cycles with not detergent to rinse away the old suds.
2: Look down in the bottom for any obstructions in the pump. Popcorn seeds, broken glass, etc.
3: If the unit is skipping the wash cycle you will most likely need a new timer or control assembly.
Good luck and I really hope this will Fix Ya
Mike
Sep 24, 2008 | Dishwashers
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
