Question about Samsung YP-U2JQB MP3 Player
Storage data I can't storage data in internal storage, i have to create a folder above music folder or playlist folder, besides my data have no date or any detail of my file. What i have to do?
You must pt it in the folder or it will not work. internal storage is for the system. It removes the dates and stuff because windows media player does it
Posted on Apr 26, 2008
Phillips 4gb Go gear playlists
ok heres what ya do.
connect to laptop/computer.
go to "computer"
find the player -- open it
internal storage -- open it
playlists -- open it
right click any of the playlists and click properties.
click the references tab.
go back to the folder called music in the device.
click and drag the songs into the window called references.
when finished click ok.
should work!
Nov 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Coby mp705-4g playlist help needed
Hello Simone, the interesting thing about the Coby MP705 is that the company decided not to reinvent the technology that already exist, but to use the Windows technology. The best way of creating a playlist is by first connecting your MP3 player to your computer. After the computer recognizes the mp3 player double click “my computer” after that double click on the icon that shows “Coby MP705” and if “internal storage” appears also double click that icon. You should now see a series of folders double click the music folder. All your music folders will now appear. Go on any music folder and right click it. You will see an option half way down that say “create playlist” by selecting this option you create that folder as a playlist. If you want to make a playlist with a compilation of assorted music you must first create a folder with all the music you would like in that playlist then follow the instructions on how to create a playlist hope this helps.
Sep 09, 2008 | Coby MP-C7085 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Getting music from cd into Insignia
if you Windows Media Player 9-11 you should go under sync and load the music that way then push sync button under the list
you can add the WMV, WMA in a raw fashon or add the playlist by dragging the playlist or indavidual song to the sync list
or
go under my computer in win XP/Vista click on the device and then click internal storage and drag the music files to the audio folder and the video files to the video folder(after making the folder)
Aug 21, 2008 | Insignia NS-DV2G MP3 Player
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
How to make a playlist for the yp-k5 in the samsung media center
My Computer, Samsung YPK5, Internal Storage, Music, Highlight the songs you want and right click to CREATE A PLAYLIST. Hope this helps :)
May 23, 2008 | Samsung YP-K5 MP3 Player
Cant transfer a playlist to my sony mp3 player
Windows Media Player (WMP) 11 in XP does not create Playlist on my MP3 MTP device. I have a Sony Walkman NWZ-S544 but I think my problem and its solution could also apply to other MP3 players that don't receive Playlists from WMP. And perhaps to Vista and Windows 7?
When I connected my WALKMAN to my PC and used WMP to Sync (transfer) Playlists to it, the songs were correctly Synched but no Playlists were created on my WALKMAN. My problem was that Windows had installed the wrong driver for my WALKMAN. Here is how I diagnosed and fixed the problem.
DIAGNOSIS: When I used WMP to Sync, the picture in WMP's right hand window was a generic MP3 device. It should have looked like my WALKMAN NWZ-S544. When I looked at the device drivers, I couldn't find a driver for my WALKMAN NWZ-S544 under Portable Devices, but instead found a non-MTP Walkman listed as a USB Mass Storage Device. (See Fix explanation for how to look at device drivers.)
Fix: To fix the problem I first uninstalled the incorrect driver and then installed the correct driver. Here's how…
  1. I disconnected all MP3 players and USB devices (Key/thumb/External Hard drives, etc) from my PC.
  2. I opened the Device Manager. Right-click My Computer-Click Properties.-Click Hardware Tab-Click Device Manager. No Portable Devices were showing. Click the + to the left of the Universal Serial Bus Controllers heading and there was one USB Mass Storage Device but it was for an irrelevant memory card reader on my PC that I can't disconnect.
  3. I connected my Walkman. Looking at the Device Manager, I see that one new USB Mass Storage Device is now showing, I right click-Properties and it describes it as a Compatible USB storage device (Walkman). This is my problem. Windows is using an older Walkman driver. My Walkman driver should be for a MTP device.
  4. I again right click the Walkman USB storage device and click Uninstall. I click OK to Confirm Device Removal. The Device Manage no longer shows my Walkman which has now turned itself off.
  5. I disconnect my Walkman and then reconnect it. Windows gives me the message that I have installed new hardware. The Found New Hardware Wizard starts. I click "No, not this time" and then Next. I click "Install from a list or specific location (Advanced)" and then Next. I click "Don't search. I will chose the driver to install." and then Next. I click "Show compatible hardware" and I select "MTP Device" under Model and then Next. Windows then finds the appropriate driver for my Walkman and I'm done.
VERIFICATION: To verify that it is properly installed, look in the Device Manager under Portable Devices (while your Walkman is connected). Click + and you should see:"Walkman NWZ-S544". Or simply look under Name in My Computer and you should see an entry for Walkman NWZ-S544, and an icon that looks like your Walkman. Everything should now work properly.
Mar 25, 2008 | Sony Walkman NWZ-S616F MP3 Player
Iriver mp3 player
Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
Feb 05, 2008 | iRiver X20 MP3 Player
Playlists
I found a little problem with this too. So I created a folder to put on my storage card. Name it whatever you want. Now take these steps to get to it to play all the songs in the folder: When you are in Windows media player, click menu, open file, storage card, The name of your folder. You should be setup to play all those songs as a playlist now. Hope this helps, I haven't messed with it anymore so I've stuck to it doing this. Good luck.
Jul 22, 2007 | Samsung Blackjack SGH-I607 Smartphone
Samsung yp-k5 mp3 player
you could also go to My Computer.
then click on your Samsung YPK5.
click Internal Storage.
click Music.
then highlight all the music you want, right click, and Create a Playlist :D
works like a charm for meeeee :)
Jul 21, 2007 | Samsung YP-K5 MP3 Player
Samsung YP-U2JQB MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
