Question about RCA 27R410T 27" TV
I NEED EEPROM NUMBER
CHASSIS ITC008FAM
    Genius:
  • 3,587 Answers
Could you provide the ic designator for this item, please?
Posted on Feb 29, 2008
Model 27r410t chassis itc008fam
What is the problem you faces with your TV? What is its model number? Brand? Provide these details please.
Jul 29, 2012 | Televison & Video
L6.1 AA 21PT1542/58
The most common problem with the L6 chassis is eeprom corruption. Replacing the eeprom will help as the newer ones don't erase so easily.
Usually the technician connects "Compair" to the TV via the three pin connector beneath the aerial input and downloads a fresh eeprom firmware set. It can take up to 10 minutes to complete the repair!
Feb 19, 2011 | Televison & Video
Can't change channels with remote
You are in need of replacing the eeprom. Location of the eeprom on the TV board is IC002. To determine the correct eeprom, you must know the numbers on IC 1001 which is a stereo decoder and the numbers on IC001 which is the microprocessor. This will determine which eeprom part number for your TV, as three different ones are available. Thanks for asking and show a few hands of support!
Jan 12, 2011 | Philips Magnavox 27MS343S 27" TV
Older tv dont know our smartlock code how do we reset?
You have a corrupt eeprom. This is a case of mistaken identity.The eeprom is located on the TV board as IC002. Locations are labled next to each tv part. This eeprom [IC002] is dependent on which microprocessor [IC001] and which stereo decoder [IC1001] is used. There are three different eeproms, and you will need the correct one for your TV. Check the number on the actual IC . For example IC001 may be MCU A22V01-T0 and IC1001 might be MSP3440. If this is the case you will need eeprom part number [location IC002] 4835 310 57593. Philps/Magnavox parts have twelve numbers and that is the correct part number for this particular example. Thanks for asking and show your hands of support!
Sep 20, 2010 | Philips Magnavox 27MS343S 27" TV
Convergence option missing from set up menu rca hd52w59
Usually if something is missing from the main menu or no longer listed in the menu, is because the Main EEPROM has crashed. To get the right replacement, you will need to have the Chassis number, (CTCXXX), at the time of order. You can order it from Encompass Elect. at 1800-638-3328.
I hope this helps
Skyassoc
Nov 15, 2009 | RCA HD52W59 HDTV Projection Television
This console has been banned for violations of the Terms of Use. To protect the Xbox LIVE service and its members, Microsoft does not provide details about console bans. There is no recourse for Terms of...
You must do the following to get access for free:
requires a virgin xbox that has not been banned (a friend's) and somewhat knowledge about computers.
Banned Xbox Live Fix - New EEPROM ' (Old Tutorial)
To get unbanned you need to purchase a new xbox EEPROM(pal or ntsc). Steps for installing it are listed below. IT WORKS. Just make sure your orginal MS info is correct and your modchip is turned off.
GETTING THE EEPROM FILE FROM THE UNBANNED XBOX
(TO INSTALL YOUR EEPROM, MAKE SURE YOU ARE USING CONFIGMAGIC FINAL* ALL OTHER VERSIONS ARE BUGGY AND WILL CAUSE PROBLEMS. ALSO, DO NOT USE THE SOFTWARE: EEPROMER)
[This is only if you want to backup your original eeprom file]
1. In EvolutionX, do the "Backup" command in the Utilities menu. It will generate files about your Xbox specs.
2. FTP in your Xbox, or use a file manager tool, and in C:Backup, you will find a file called EEPROM.BIN
3. FTP that to your PC HD or remember its location for future reference.
SETTING UP THE FILE FOR CONFIGMAGIC FOR THE BANNED XBOX:
1. Once you have Configmagic loaded onto your HD or on your PC, there will be a directory in it called DATA.
2. Move the EEPROM.BIN file, the new unbanned EEPROM you purchased, into that DATA directory, overwriting the EEPROM.BIN file that is already there.
3. If you are making a Configmagic CD, you can now make the ISO of it and burn it. Xbox HD users, don't worry.
RUNNING CONFIGMAGIC:
1. Load up Configmagic.
2. A warning screen will be shown, press "A" to bypass it.
3. When Configmagic finally loads, it will show your current EEPROM on your Xbox. Make a note of the DVD KIT ZONE and VIDEO AND XBE REGION information. "NTSC, Region 1" for US Xbox gamers "PAL, Region 4" for UK Xbox gamers
4. Select "LOAD XBOX EEPROM" in the menu.
5. Select "UNLOCK HD" in the menu.
6. Load the EEPROM.BIN file in the DATA directory by choosing "LOAD EEPROM FROM .BIN FILE"
7. If you see that the VIDEO AND XBE REGION information is different, you MUST change it. Go into the menu and choose "ON-THE-FLY EDIT EEPROM". Change the VIDEO AND XBE REGION number to the proper information of your former EEPROM.
8. Now, select "UPDATE XBOX EEPROM" in the menu.
9. Your Xbox's EEPROM will now be updated with the file in the DATA directory.10. In the menu, select "LOAD XBOX EEPROM". You will notice your EEPROM is now different! Success.
11. Select "LOCK HD" from the menu.
12. Select "EXIT CONFIGMAGIC" in the menu.
IMPORTANT TIPS:
- If you were using the XBOX DVD KIT to play DVDs, and the Xbox gives an error about region, load up Configmagic and change the DVD KIT ZONE number to the number of your previous EEPROM. UNLOCK the HD, choose "ON-THE-FLY EDIT EEPROM" in the menu and simply change the DVD KIT ZONE number. Then, UPDATE XBOX EEPROM and LOCK HD. Exit Configmagic.
- You can view any Xbox EEPROM using your PC by getting Liveinfo PC program. It will show all the details of an EEPROM.BIN file. You might find it easier to edit any possible changes to your DVD KIT ZONE or VIDEO AND XBE REGION using the program, rather ON-THE-FLY EDIT EEPROM in Configmagic.
- Sometimes, with a PAL EEPROM, your Xbox's time might be wrong or video settings will be different. Go into the MS dash and change the settings to the way you seem fit.
Special Notes:
- If you were banned with your original eeprom, once you replace your eeprom, you will need recover your account. To do this, simply select the account recovery option. Once this is done, you will need to verify some personal information in order to retrieve your account.
Nov 07, 2009 | Microsoft Xbox 360 Console
Need a code for a citreon saxo car radio please. Serial number CL0402Y0351889 model number PU-2294B(D) Lost code when battery was changed. Thanks for your help.
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
There is a 20% chance of you having this barcode Serial Number
If you have this Barcode Serial Number on your radio then
POST A NEW QUESTION
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Oct 10, 2009 | Car Audio & Video
I have a GE Television that was manufactured in Nov 1995. I can't get it to turn on. I know the power source is good. I suspect that the internal fuse blew and I am looking for the schematic so I can...
The chassis series used in that set was notorious for bad solder connections around its tuner and a few other places. (They used the tuner shield to provide a number of ground connections, and these cracked and went flaky.) These connections would cause a variety of problems including a set that won't turn on.
The fuse is located right near the AC mains cord connections on the board. You will probably find it's good. Not much went wrong on this chassis to blow that fuse unless it was power line troubles or shorted parts on the power supply primary side.
Check for 5 volts at one of the 3 pins on the the remote sensor. If the power is there, you probably have a bad EEPROM IC. Operating parameters and TV settings are stored in that chip, and the bad solder connections I mentioned above can lead to the data getting scrambled and a "dead" set. To repair this, you need to resolder the connections at the tuner shield and a few other locations, then replace the EEPROM.
If you Google "RCA tuner solder problems" or something similar, you should find all kinds of information about where to solder. The replacement EEPROMs are available from MCM (www.mcminone.com) and you order the appropriate IC for the chassis. I'm not home now, but when I get home later I'll check my files for the service bulletin RCA released, and look up the EEPROM you need in case that turns out to be the trouble.
Apr 27, 2009 | GE Televison & Video
RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
Dec 21, 2007 | RCA TruFlat 27F520T 27" TV
RCA 27R410T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
