Question about Yamaha Audio Players & Recorders
Yamaha DSP-A2070 I have a Yamaha DSP-A2070 receiver, with pre-amp/amp communication problems. knobs under the front door (bass, treble, balance) don't work. DSP effects must be on for any sound to work...can't just play in stereo. If I push the "effects" button to turn effects off, there's no sound at all. Also, the remote tended to learn the functions of my cheap sanyo dvd/cd player, and whenever i push a button on the remote, it'll restart the song or skip to the next one...which seems really weird. Anyone able to help me on this one? Perhaps it's a simple setting.
Check the 'front mix' switch on the back, set it in off; main level on max.
Posted on Sep 10, 2008
Yamaha dsp a2070
is the 'tape monitor' function turned on?
Mar 29, 2014 | Audio Players & Recorders
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
Yamaha DSP-A2070 not working, and not power up in standby mode. All the fuses is OK. Please help ?
start reading on page 14 of your service manual.
let me know if you need further assistance!
Aug 20, 2012 | Yamaha Audio Players & Recorders
Need to know how to adjust bass, treble, fade, etc. on Alpine model CDA-7862
Press the MODE knob to choose between bass, treble, balance, or fade.
Turn the MODE knob to change each setting as it is displayed.
Mar 15, 2011 | Car Audio & Video
Yamaha AX-596 Integrated Amplifier only works when using either of the two "Pure Direct" buttons. The Bass, Treble, & Balance controls do not function. It would appear that circuit board or the circuit...
Chances are that the tone control pre-amp circuit is faulty. These days the functions are all done by a single IC. Find that and you will more than likely have found the culprit. If there are any of the controls for bass etc on the front pannel, trace the wiring back from them. If not have a look around on the PC board in area that you suspect (some boards are marked as 'tone' etc). If you see any IC's put the number into google and you might find out what each does. Keep doing it till you find one that deals with tone etc.
Aug 20, 2010 | Yamaha AX-596 Amplifier
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
Yamaha DSP-A2070 intermittently fail to output audio to speakers
Hi...
Is the source selector a round rotary switch knob?
If it is the insides of that switch will need a good flush with contact cleaner.
Mar 27, 2009 | Audio Players & Recorders
Finding how to set the treble and bass
Under the silver volume knob is a thin silver bar. Push it and the menu will pop up on the screen. Continue to push this bar to scroll through the different options. It controls bass, treble, balance, fade, sub volume etc. Good luck, hope this helped.
Dec 19, 2008 | Alpine CDA-9833 CD Player
769 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
