Question about Kitchen Ranges
Fridgidare PLES389DCB top left rear element stopped heating after a bright flash from under the top. Looked like it shorted out, now the right rear element flashed undr the top. it didn't stop working yet like the other burner. What's the deal and how do i fix it.
  • scott cale Feb 29, 2008
    it's a ceramic glass top stove
    Genius:
  • 1,665 Answers
wiring diagram: ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318045090.pdf
Parts Manual: 5995397410
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995397410.pdf
See pages 6,7
15 # 318198810 Element,surface ,6" ,1200 W
15A# 318177910 Element,bridge
15B# 316224300 Element,dual ,6"/9" ,surface ,1000W/2500W,radiant
15C# 318198804 Element,surface ,warmer ,100 W
Posted on Feb 29, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 29, 2008
    disassemble the unit and as shown and check the rear right surface elements 15 15c and their wiring.Replace faulty parts.
    Sergeant:
    Champion:
  • 281 Answers
Best Buy
    Genius:
  • 3,587 Answers
Hmmm..flashes under the top(as in the hood)..I suspect you have some faulty wiring. Only way to find out..
unhook power
remove hood/top
visually inspect wires for fraying or cuts(sometimes critters will do this too)
report back, ok?
Both fron turn signal flash when selecting a right or left turn, but rear lights work fine.
check the elements in the light bulbs sometimes they short together
Aug 23, 2012 | 1999 Chevrolet Lumina
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Model DEGX1. Placement of tall and short heating element
The picture on PAGE 56 has the taller element to the left.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 24, 2010 | Fisher and Paykel DEGX1 Electric Dryer
How do you replace the heating element in a Maytag PYE-2300
Unplug the dryer cord.
Use a putty knife to release the 2 spring clamps holding the top lid to the front panel. They will be about 2 inches in from the right and left sides where the top meets the front.
Raise the top lid and fold it towards the rear of the dryer.
The heating element will be in the back left corner.
Remove the hi-limit thermostat on top of the element. Remove the element retaining screw and remove the element.
You should replace the hi-limit thermostat also.
Dec 14, 2009 | Maytag Dryers
A bright light flashed in the oven and now it is not heating up what can be wrong the fan is still working though and the grill
Check the thermal fuses / sensors mounted on the top exterior of the heating chamber and also the heating element. Both accessible from the rear of the oven. The element is most likely to have gone. It will be a 2 or 3 turn coil type with the fan mounted to the middle of it. You will need to check the number of turns of the coiled element and also the mounting holes to ensure you get the right type. Turn off the mains power at the breaker or distribution point. You can get to the element behind the rear plate of the oven cavity by removing the side shelf slides, and rear panel by undoing the securing screws on the plate (2 or 4 depending on the exact model you have). Often a good idea to take a photo of the element mounting and take the model and serial no of the oven so that you can take this to the domestic appliance shop or email it to an online supplier to make sure that the element they supply is correct for your exact oven.
Nov 08, 2009 | Electrolux EOB5600 Ultrafan Electric...
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Boiler U/S?
Take off the water tank, you will se one screw in the chassis, look in the beenhopper and there will you see two screw, loosen this to. Open the door and look up to the right corner and left corner there will you see one screw in each corner, loose this. take of the steam knob. Take of the top.
Look at the right corner and you will see one screw that has to be loosen. If you have to change the boiler you can put a screwdriver in the hole on the right side between the top and chassis and ****, now you can lift up all and work with it on the table.
Sep 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Kitchen Ranges Logo
334 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
