Question about T-Mobile Dash Smartphone
My Tmobile dash will not turn on. When I put it on the charger, the green light comes on (and it charges), but when I attempt to turn it on it does not come on.
  • 11 more comments
  • Anonymous Mar 10, 2008
    THE WILL DIE AND I PLUG IT IN THE YELLOW LIGHT COMES ON AND THEN TURNS GREEN. WHEN I RESTART IT THE PHONE STARTS UP BUT THEN WILL STAY TO TO TMOBILE SCREEN THEN DIES AGAIN
  • Anonymous Mar 12, 2008
    Same as above. It charges, but does not power on.
  • wemilr Mar 22, 2008
    Same problem. Dash comes on but not completely...then goes off...and keeps repeating, What's up? wrissel@msn.com
  • DaniScottx3 Mar 28, 2008
    I AM LITERALLY ON MY 3RD DASH!!
    same problem with all of them.
    won't turn back on. replays start-up animations?!
    someone help!!!!
  • Damenia Apr 02, 2008
    this is the exact same problem i have. Its crazy because the green light comes on and stay on and then when i take it out of the charger it dont come on. can you PLEASE HELP ME?
  • W.C. Teghtmeyer Apr 13, 2008
    Same problem -- will not turn on. Unit is fully charged. Have tried holding the start button at least 10 seconds and it will still acts like its dead although the green light is blinking (on charge).
  • C-milly Oct 27, 2008
    i have the same problem but i'm only 12 idk what to do
  • fresh2death0 Nov 15, 2008
    i have the same problem and this solution doesnt seem to work, unless i am not doing it right
  • Anonymous Nov 17, 2008
    I dropped my phone and now it will not turn on?
  • dewflavoured Dec 15, 2008
    mine does the exact same thing! i tried reseting it, but it still doesn't come on!
  • shanem187 Dec 17, 2008
    same problem as everyone except when i put mine on the charger it wont even light up no green light no yellow light..at first i thought it was just my outlet so i changed outlets..same thing..then i thought maybe my charger so i hooked my dash up to my comp...nothing..still no light or anything...
  • linseyy May 05, 2009
    I dropped mine and now it wont turn on. When i plug it in, the yellow light comes on, but it wont turn on. Ahhhh what do I do? I tried resetting and it didn't do anything
  • Anonymous May 14, 2009
    I did try all the above mentioned methods but no luck please suggest someother method
  • 44 Answers
It may be the storage card - if you take the storage card out it will boot up and you can put it back in. - pain in the a## but it may work. Or Try taking the SIM card out, boot it up, turn it off, replace the card, and turn it on again Last resort is a hard reboot to set it back to factory default. reboot system by holding down the two - - keys above the house and arrow while the phone is off. Then you continue to hold while you push the power button on the side for 2 seconds. Should go to white screen then black screen. once at black screen hit the green call button and follow the rest of the prompts.
Posted on Mar 28, 2008
  • Gavin Mar 30, 2008
    To perform a hard reset (Erase ALL your data) on the t-mobile dash hold the two soft buttons down or dash buttons labeled - - then while holding those buttons hold the power button for 2 seconds you will get a prompt to press 0 to reset. Time is of the essence if you miss it try again.
    Edit: Here is a second easier method:
    If you cant get this to work you can navigate through these steps as well:
    Dash Hard Reset
    1. Select Start
    2. Accessories
    3. Clear Storage
    4. Type 1234 in the box
    5. Select YES.
  • Gavin Apr 07, 2008
    Sorry the instructions I gave earlier for the hard reset was incomplete, Here it is complete.
    To do a hard reboot.
    - with the phone powered off
    - press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
    - while keeping it pressed, press the power button down
    - keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
    - now release the soft keys and follow prompts
    - if you dont see the black screen with the reset option, pull the battery out, reinsert it and repeat the above steps
    - when you see the black screen with the reset option, press the Send button to confirm the reset.
Open the tombile dash and u will see a cricular thing under the memory card slot and move it around under the back cover this is it it will work after this i fixed it this way
Posted on Aug 14, 2009
Wen i turn my dash on it goes to the green screen and it't stay they like it is frozen and it wont proceed to the next screen
Posted on Jul 24, 2009
Memory card was the problem with mine. I took it out and the phone started right Up. I will not insert the memory card again.
Posted on Oct 05, 2011
  • 4 Answers
Check this link this might help and you might need to get a new battery. Call T-mobile if they dont do anything about it complain to the better business bureau.
http://rapidshare.com/files/158051189/Windows_Mobile_6.rar
Posted on Oct 27, 2008
I dont know if this may help but the first time i took it to the shop they told me there was something wrong with the power button i dont know if that helps
Posted on Aug 16, 2009
I jhave a Jazzy Select GT power chair, I put the charger on it when the light shown red and green, when it powers up when charged the both lights will turn green, but now it will do nothing with start
Hi Gloria,
The first thing you need to do is measure the voltage at the charging socket of the Joystick (outside 2 pins). This will determine a lot of things, so I can guide you further.
Nov 21, 2014 | UPG 12V 35AH Jazzy Select GT Power Chair...
My Air Force infared control 2 in 1 helicopter wont charge. (The light wont come up green)
Found a previously posted solution here:
http://www.fixya.com/support/t13972794-havoc_heli_won_39_t_charge
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Dec 25, 2013 | Spinmaster Air Hogs Red Defender Remote...
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
Just got this little dirt bike from a yard sale. Trying to figure out charging the battery. When I put the charger into the outlet, the little green light comes on. Then when I connect black charger end...
the charger led should turn orange or red when charing then turn green when finished charging, but without knowing the model of the charger its had to say
Dec 12, 2010 | Peg Perego 12v Battery
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
My tmobile phone will not turn
try to plug in thew charger. if it indicates that it is charging then you most likely have a broken power switch. that is a common problem with this phone. if youcan get a local cellphone repair tech to service it, contact www.fixphonenow.com they can repair it.
Nov 15, 2008 | T-Mobile Dash Smartphone
T mobile dash
This happen to me more than once, the latest today (may 25 08)at 9pm. Tmobile will tell you how sorry they are and that's about it. I am on my second dash and second battery.
Try to hold both top keys (between call green and hung up red) while you are pressing on the shut off switch for 2 seconds. Whe it comes back to life, everything will have erased but supposedly, the phone will be like new.
I am collecting names and emails of people who are fed up with the Dash and Tmobile. Write to me jeanrenoux@hotmail.com
May 24, 2008 | T-Mobile Dash Smartphone
Tmobile dash is getting me p'd off
Mine does the samething. I'm running 6.1 and have found the problem to be the system fails to read the sd card on boot. When I reset my memory I don't put the sd card in until the system has booted back to the start screen. Works fine everytime.
Apr 15, 2008 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
4,147 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
