Question about EPoX EP-4PLAI Motherboard
Good am its an audio jack
  • Hairy29 May 11, 2010
    good am...
    audio jack connected to the mobo?i think your front panel audio has an audio jack connection which will be connected at the back panel audio...and not at the mobo,right?is the audio jack green and pink?
    thanx...
  • 73 Answers
just brief out the details its an motherboard it has audio jack
regards
shailesh
Posted on Mar 13, 2008
What can be connected to te audio output jacks on the back of this set?
You didn't include make and model TV; so only generalized answers are possible.
Typical RCA phono jacks like those shown in the blue box of the stereo amplifier below:
25998201-ac5bgneb45fvu53muoueauti-3-0.jpg will accept cables to connect to other audio devices. The audio RCA jacks are color coded RED (right) and WHITE (left) for low level stereo signals. Some have YELLOW jacks for Standard Definition video, ORANGE jacks for AC3 Digital audio and newer amps have HDMI jacks.
Connect the TV's audio OUTPUT jacks and a stereo pair of unused audio INPUT jacks on the amplifier with cables that have ends that match each. Turn on the stereo & TV and select the input on the amplifier that matches the stereo pair of inputs you used to connect to the TV. Adjust the volume to hear the audio over your stereo system's speakers.
Use the HDMI or AC3 sources for superior audio - including 5.1 (or better) Dobly Digital when possible. Otherwise, a standard 2 channel stereo program will be heard.
I hope this helps & good luck!
Dec 08, 2015 | Televison & Video
Hii my name is.Jonathan I need to ask u guys I have to fix RCI flat tv every thing ok but in.audio it have problem I.check capacitor it is good and audio IC it is good so what is the problem
You can try using the audio-out jacks as a source for adding a pair of speakers. If they are dead, try using the headphone jack (if it has one). If that works, you can use a set of speakers such as used with a computer as a ''work-around'' for your problem. // With regard to your specific problem, you'd need a complete schematic to follow all of the potential problem locations. // If the audio IC is good, it can be a bad smd resistor, which is likely not replaceable... In other words, in all likelihood, you'd be looking at replacing the entire audio circuit board to resolve this issue... That's why I suggested trying the audio-out jacks and/or a headphone jack as a ''workaround''. They are frequently on a different circuit.
Sep 02, 2015 | Televison & Video
Trying to connect pc with hdmi cable have great picture no sound on TV Used HDMI imput 7 tried imput 6 with hdmi and audio imput from PCF to TV still picture and no sound any suggestions
Hi Scott,
On your PC, you'll need to go into the Control Panel --> Hardware & Sound --> Sound (Windows 7) and click on "Playback". Here, you'll need to change the sound settings to reflect the audio to be handled by the video card / audio chipset / HDMI jack on the motherboard. You should also check for other settings such as Digital Output that are usually associated with and HDMI jack on the card and not an analog jack.
As it is now (or is likely to be the case anyway) the picture is being handled by the HDMI on the video card / motherboard; but the audio is still coming from the the speaker jack(s) on the motherboard or audio card. Making the changes above will redirect the audio from the speaker jack(s) to the HDMI jack instead.
Mar 27, 2015 | Sharp 52"" aquos lc-52sb55u 1080p...
Dvd has no sound.
hi check first if the problem is not with in the tv monitor. if the tv is not the problem check the connector coming from audio jack of the dvd player replace if defective.re solder audio out jack terminal at the board of dvd player. then make sure you have proper wiring of connector from audio out jack of dvd player going to audio input of tv monitor.thanks good luck.
Jun 16, 2011 | Toshiba Televison & Video
Can't get my Proview TV to recognize the signal
Good day!
Please check the connection of the jack from your TV to DVD.
Follow this step on how to connect the AV (audio and video) jack.
  • For the DVD connection.
  1. Find out where is the video out of the DVD.It is usually have a label (video out) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video out of the DVD.
  3. Next,find out where is the audio left and right out of the DVD.It is commonly have a label (rear,front and center) choose 1 of the location you want.also it have a standard color (red and white)
  4. After that,connect the AV jack(red and white)to the audio out of the DVD.
  • For the TV connection.
  1. Find out where is the video IN on the rear side of the TV.It is usually have a label (video in) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video IN of the TV.
  3. Next,find out where is the audio left and right IN of the TV.It is commonly have a label (audio in ) and found in the rear side of the TV.also it have a standard color (red and white).
After you connect the AV (audio/video) jack.Try to open the TV and the DVD and set your TV to the AV mode by pressing the AV label on the remote or on the TV button.
If the video is not appear on the AV1 try AV2 ,AV3 and so on.Or also try other AV on the TV.
I hope this solution will be helpful.Thank you and good luck.
May 06, 2011 | Televison & Video
Back panel audio jack is good condition I hear from back panel audio jack but front panel audio jack is not working.
hello,
Go bios prees by F2 / F10 /del set the azilla audio enable .
Reinstall the audio driver again.
Hope it will help you.
Dec 23, 2010 | ASUS P5KPL-AM - Motherboard - micro ATX -...
My audio out put is damaged, any way to re-route
Audio jack on any mother board runs on Mic and Headphone outlets.
The design of the board and the chipset wouldnt allow the headphone to be used in the microphone jack. Instead you have the option of using usb headset which has a driver pack to be installed and it goes fine. I am not sure if you have the product available at all stores. Good Luck
Feb 15, 2010 | Microsoft Windows Vista Ultimate Edition
Audio not coming out input 3 in
input to the tv is incorrect select av3 0r what ever the front jack is marked on you tv. good luck farr64
Apr 30, 2009 | Mitsubishi WD-73735 Television
Hooked up dvd and vhs player good picture no sound please help
look carefully whether you jacked the audio out from DVD and audio in into the TV
> the TV is having a Audio out and in jacks
>if you jack a the audio out from DVD into Audio Out in TV you wont have audio
May 08, 2008 | NEC MultiSync LCD4010 40 in. Television
One audio channel is not working
1.check whether the audio.rca jack cable is good
2.check Rca jack connector
3.there might be a problem in your stereo audio processing circuits
4.Contact service centre for further rectification
Nov 21, 2007 | NAD L40 CD Player
EPoX EP-4PLAI Motherboard Logo
41 people viewed this question
Top EPoX Computers & Internet Experts
Marvin
Marvin
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
